79 Mustang lean as a bean |
Post Reply | Page 12> |
Author | |||
KooK
Senior Member Joined: February-10-2014 Location: Iowa Status: Offline Points: 143 |
Posted: July-03-2017 at 2:15am |
79 Mustang 17 w/ 302 Commander
10:1 compression GT40p heads Fuel pressure set to 5psi Stock 4160 Stock intake manifold, stock exhaust manifolds, stock cam Kind of a crappy picture (angle), I apologize, but I'm running lean. Plugs were evaluated after a 2500-3000 rpm cruise and engine shut off without idle. I assume the only thing I can really mess with here are the main jets? I assume Holley stamps the jet sizing onto the jets themselves? Thanks! |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11093 |
From one of your old threads you have a Holley list # 7159 450 cfm carburetor that had # 59 jets as original equipment. It also had an 8.5 power jet in it.
Right now you have a 6.5 in yours, see the picture in your other thread. 59 mains have a .058" hole That's not a typo, you'd expect 59 mains to have a .059 hole but they don't Here's a Holley main jet chart Your size should be stamped on the jet itself but sometimes old ones are tough to read since it's small and stamped on the end. Sometimes you'll see the stamping on the side of one of the hexes You're right though, can't tell much from your picture but if you think you're lean go up a few jet sizes and put in an 8.5 power jet |
I don't think you can properly evaluate rich/lean from looking at that picture. How wide is the soot ring at the base of the insulator?
KooK
Question, am I correct in saying the carb is a 4160? You're right that the carb says 7159 but I'm under the impression that it's of the 4160 family of Holley carbs?
I'm going to go ahead and order up that 8.5 power valve and a few jet sizes between what I have (the 59) and probably 70 and see what everything looks like. Thanks again Keno! |
KooK
I have no idea why I took that picture at the angle that I did. I'm heading out again today after a quick rejet. There was basically no soot ring though. |
Yes it's a 4160. The list # is 7159
The list number if you look that up will give you the specifics for that carburetor. |
GottaSki
WHoah don't go yankin and bankin
No changing things simply due to a white insulator. Not enough information yet. White means you are spot on or damn close. Look at fuel injected engine's plugs, they will look similar. Your plug looks just as it should. To learn more, one must look inside. And, its most useful when confirming one circuit, then adding the other. Else you don't know whats amis, if anything, or which side to mod. Appears you kept the rpms with the primaries only, but its best to just wire the secondaries shut and go WOT. Plugs must get hot to self clean. Your's are doing that. Heat means power (its a heat engine) Like Tim sez, you need to get a plug scope or cut the threads off a plug to see and measure the soot ring width. First running on the primaries, then inspect or tune, then add in the secondaries, else you will screw the pooch. DONT expect a 8.5 PV to increase the fuel volume, nor change the way the plug looks one bit. . Its only for tuning the transition between lean cruise high vacuum, and heavy load low vacuum, a very short window in the operating mode of a boat engine. There is a method, just warning changing things chasing a white (clean) plug, is going to be no fun without proper methodology. Putting it another way, If you tune it till the plug insulator tip darkens so you feel better,, you will be giving up power. |
River Rat to Mole |
KooK
I need to go out again and do plugs at different loads. You're right about the soot ring, but I still feel as if I need to go a step or two colder with my plugs. This was a fresh plug on a WOT run. Almost no idle time except to confirm oil pressure.
Ford 302 Commander 10:1 compression GT40p heads 8.5 power valve (stock) #65 main jets (#59 stock) (The picture of the band did not turn out, only this picture) |
KooK
Question, can I change the weights out in the distributor that increase timing up top? I need to dial it back 2-4 degrees due to light detonation but I don't want to lose my timing down low.
Springs not weights but, even the standard springs are hard to find. What's your base timing set at? What octane gas are you running?
Springs can change the shape of the advance curve but will not change total amount of advance (unless that heavy spring is really heavy ha). You would need to adjust the stops to take some timing out of it.
Here's a picture from your other thread
Those slots in the advance plate that the pins on the weights ride in limit your total advance. Your's is made of nylon and those slots should give you around 34 to 36 degrees total advance if you initial is set at 10 Like Tim said you can bend the tabs that the spring ends hook to and affect the rate of advance but not the total advance unless you bend the tab enough to really stiffen things up and prevent the weights from hitting the stop.. Doing that is pretty much a crap shoot and probably won't have good results What's your timing curve look like now. You say you had 10 initial in the other thread, so what's your total at say 4000 rpm. Better yet, what is the advance at 1000,2000,3000,4000 rpm Most people have a hard time getting full advance from that distributor because of the big stiff spring but I guess you're not having that problem. Why don't you just back the initial off and see how things run as a starting point ? |
KooK
If that's the case then I will just back the timing off from 10 degrees initial and see how it acts.
Question, does anybody happen to know what stock compression ratio was? For some reason I was under the impression that it was higher than what it probably was. |
In 1979, probably about 8.3 to 8.5 to 1 or so,
Aaron, I'm curious as to where you came up with the 10:1?
KooK
Bore diameter: 4.030in
Stroke: 3in Cylinder head volume: 57cc Piston dome volume: +2.7cc Deck clearance: .01in Compressed head gasket thickness: .040in (Roughly, this number came from Fel-Pro) I rebuilt the engine, put new pistons in with GT40p heads, resurfaced the heads, decked the block, CC'ed the heads and came up with about 10:1 compression ratio. This is why I'm messing with carb jetting, plug heat, and timing. Somebody earlier mentioned octane rating, it's difficult to find above 91 octane here so I've been running 91. Typically on a street SBF build, you don't want to run above 10.5:1 on this fuel if you want to keep it mostly hassle free from detonation, I keep tripping over tuning though because I'm not used to this type of control and I haven't had to read plugs in at least 10 years. I'm very much used to running a wideband anymore. Honestly, it's like I'm pulling my hair out half the time, and loving all of this the other half. |
I would consider replacing the stock 450cfm Holley with a 600cfm (stock jetting probably fine but do check) with a hotter 302 like this.
KooK
I'll eventually go up to a 600 but it probably wont be this season unless something happens. When I get a 600 I'm also going to end up porting the heads, gasket matching the exhaust, a little more aggressive cam, running a different prop and so on; but that's more research for a different day.
Right now I finally found my old books and notes on reading spark plugs, but I'm probably going to be in for a new spark plug inspection light, which is fine because I'm going to have to cut these plugs first anyway. Tomorrow I'm going to gap some new plugs, take it back out to the lake again and make a few more test runs and actually come back with usable data. I'll get my timing set out there first, then get a run to check to see what my fuel looks like, after I get fuel dialed in I'll play with the spark plug heat range. I just want to make it safe for now. |
No need to do any of those other modifications in order to swap to a 600cfm carb (that would have been a must-have with the heads and higher compression IMHO). A stock-jetted 600cfm would get you into the safe zone on the jetting and won't be a bottleneck on the air flow. That way you'd be doing your jetting changes in the safe direction (starting fat and going leaner- rather than the other way around). Just an opinion. PM me if you want a rebuildable 600cfm core, I have some spares.
GottaSki
Tim and KENO are spot on, best heed
As been said, I would also further encourage reducing the span on the distributor asap, so your not tempted to run too much total advance just to get back the strong off-idle and launch 10btdc provides. Total advance will have to be reduced if the compression is as high as you say, due to the faster moving flame front and faster peak pressure developed. To only way do do both, is to reduce the mech advance span, and weights /springs is not equivalent.. Also, a colder plug has to be considered for the right reasons. To make it look like its not lean, is not the right reason. Predetonation, may be one, but the timing has to be spot on and eliminated firstly. Think of the plug asyour gauge, once one goes changing gauges, things get blurry very quickly. Something has to be held constant, till the method and evidence is sound. This thing must sound good with domes and flat-decked. |
River Rat to Mole |
Kinda curious what your detonation indications are.
Your stock secondary metering plate would be a #134-8. That has .067 main holes which basically function as the main jets for the secondary side and has .026 idle holes. You might want to go to bigger main holes to richen up the secondary fuel flow. Something like a #134-6 would have the same size idle holes and .070 main holes for example. You can find a chart or listing on line. |
Or consider a rear metering block conversion kit (uses replaceable jets instead of the fixed plate. I'd still go 600cfm to start with, though. Makes tuning much easier.
KooK
None, I misread the plug. I apologize, I'm relearning how to do all of this again and I jumped the gun in saying that. |
Dreaming
summit racing has secondary metering blocks to convert a 4160 to a 4150. I think you're playing with fire to run too lean like this, detonation could ruin all the work that you have just done to make what sounds like a nice motor. Jody had some $25 cores a few weeks ago, and sounds like Tim has some he is willing to sell. That and a carb kit is going to be much cheaper than a motor rebuild if you have a detonation problem or too hot of a burn. you might even have some lookers for that 450 CFM to offset the cost of the core/kit
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 974 |
I'd help you offset the cost of the 600 by taking the 450 off your hands.
Kook
Here's something I put in another thread yesterday but it pertains to you too It's power valve info and it'll tell you something about when your power valve opens and closes A lot of people aren't gonna want to believe what I'm about to say, but if that's the case they can verify some readings for themselves. You always hear that boats run under constant load and then when a power valve discussion pops up, somebody will say that when you punch it from a dead stop, vacuum goes to zero and quickly recovers. It don't happen that way though If you give it full throttle vacuum drops to zero and stays there till you back off the throttle. If you run the boat at a steady 4000 rpm's vacuum stays steady, it never recovers to a higher vacuum till you back off the throttle. Same thing at any RPM in a boat that's operating under a constant load. Here are some representative numbers on a good running 351 that I wrote down a couple of years ago and verified again with a quick boat ride tonight Full throttle zero 4000 rpm 2.5 inches vacuum 3000 rpm 7 inches 2000 rpm 9.5 inches 1000 rpm in gear 13 inches idling in neutral 20 inches This particular boat has a 6.5 power valve so it's open whenever the boat is going over about 3300 rpm All these numbers can vary some from what I have depending on engine loading, hull efficiency etc but they'll be steady at whatever reading you have till you move the throttle. It's the concept we're after here. And remember it ain't a car. Like I said, it's bound to lead to some discussion, but you can check it for yourself easily enough. You can hook into your PCV line to measure vacuum and use enough hose to get the gauge out where you can see it. So Kook You'll figure out that your power valve is open a lot of the time adding fuel to the engine. Sounds like you went to an 8.5 so any time your vacuum is less than 8.5 it's gonna open and stay open till you back off the throttle. |
GottaSki
Good stuff Ken,
Confirms my experience of cursing the dull throttle response compensating 34-36mph slalom on a boat with the now - default 2.5 PV supplied in kits and new carbs. Boat engines should be out of lean cruise long before then. |
River Rat to Mole |
Just bought a brand new 450 cfm Holley with a 8.5 in it. Is it possible only the 600's have the 2.5 ? Wonder how they determined a 450 needs a 8.5 and not the 600 too?
tryathlete
Platinum Member Joined: April-19-2013 Location: Lake Villa, IL Status: Offline Points: 1797 |
Gary, is the 450 for the Florida boat? I would think the HMM could use a 600! I had a 450 on my old V6 Capri.
Hi Gary I dug through some carburetor list numbers and found 7 450 cfm marine carburetors with different list numbers and they all had 8.5 power valves as standard equipment. I'm sure there must be more than 7 but that's what I came up with doing a quick check I suppose somebody at Holley knows, but since it's really just an auxiliary main jet that opens and closes at a certain vacuum setpoint, it must have been part of their calibration process. It puts the fuel in through the power valve channel restrictions in the metering block and they have different sizes in different metering blocks for calibration purposes.And those PVCR holes come in plenty of different sizes in different metering blocks I figure I'm not saying anything you didn't already know though. That doesn't really answer your question or our curiosity though |
