  New Posts New Posts RSS Feed - 20w Motor Oil for PCM Transmission
rsgirdner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rsgirdner Quote  Post ReplyReply Direct Link To This Post Topic: 20w Motor Oil for PCM Transmission
    Posted: August-29-2017 at 8:18pm
I have a 1990 Sport Nautique that I purchased new. It came with 20w oil for transmission fluid. I have only been able to find 20-20w oil for it. I can not find 20w oil. Can I use the 20-20w oil in the transmission? I know that PCM said you should change to Dexron III. But that requires several flushes to get all of the oil out of the transmission. I have been happy with the oil in the transmission. Not sure I want to flush the transmission three times to get the oil out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2017 at 8:33pm
The PCM manual I just looked at shows the 20-20W as the preferred oil back when that manual was printed. It's an old manual from before the recommendation became ATF
That matches what you can find so it shouldn't be an issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2017 at 9:16pm
20w = 20w20
I'd still change to atf due to cost and availability.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2017 at 10:03pm
20w = 20w20
But he doesn't want to
Sounds like a case of "If it ain't broke, don't fix it" in his case
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2017 at 10:17pm
Why did PCM change it? Didn't they have a vibration problem or something early on and thinking that would fix it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-29-2017 at 10:48pm
It was supposed to fix the infamous whine the 1.23's were/are known for, but I don't think it did.
They also had a buzz that had a fix that was a 10 inch or so hose.
The buzz and the whine were different.
I do remember in my younger days I could get a buzz from some wine though
Mad Dog 20-20 was cheap and effective
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary S Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2017 at 12:06am
Having a V Drive I never noticed any transmission whine or any noise out of it at all But in spending some time in the back seat I am surprised how loud the intake is. I don't know if other gt40's whistle like that but it does not stop until it gets up to the speed you wanted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote rsgirdner Quote  Post ReplyReply Direct Link To This Post Posted: August-30-2017 at 6:15pm
I want to thank every one for their replies. I purchased a case of Kendall 20-20w oil to use for future transmission oil changes. I had been using Valvoline straight 20w. But it is no longer available. Hopefully the Kendall oil will not cause any problems.
