  New Posts New Posts RSS Feed - 2003 196 Steering Cable Replacement
shea.95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote shea.95 Quote  Post ReplyReply Direct Link To This Post Topic: 2003 196 Steering Cable Replacement
    Posted: June-07-2018 at 11:29am
The steering on my 03 196 has gotten really bad. I am planning to replace the steering cable but have had a hard time finding directions on how to do so for this model boat.
​​​​​​​My current understanding is that the rudder side of the old one is detached, then the steering side is detached, the rudder side gets a rope tied to it and pulled through to the front, then the new one is attached to the rope and pulled through and then hooked up on both sides. I am wondering what all needs to be taken apart as far as the boat is concerned for this project. Also just general directions on the steps of how to complete this project.
I would really appreciate any directions, tips, etc.! Especially if there are any peculiarities with this model 196 in particular. Thank you!
Thank you,
Andrew
Bri892001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 12:13pm
I did this write up when I did mine:
http://www.correctcraftfan.com/forum/forum_posts.asp?TID=31166&title=steering-cable-replacement-with-pictures
Mine is 1993, but I'd think the steps are mostly the same. You'll probably want a helper to help you feed in the cable. And, this job is easier with the motorboat out of the way. And, you'll need to get the removable portion of the floor behind the motorboat out of the way. Also, any part of the rear seats that you need to get out to get out that floor panel.
Not hard, just takes a little bit of patience.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shea.95 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 12:25pm
Thanks for the info! This is helpful.
My 03 196 has the gas tank under the rear seat and a ballast in the far rear of the boat. Any info on how to get to the rudder connection without removing the gas tank?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 12:36pm
You're welcome, no problem.
Hmmm, hopefully someone with the same gas tank setup will weigh in. On mine, I had plenty of clearance with the gas tank placed well into the stern. Once you get the floor panel up, it might illuminate things a bit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 12:59pm
Have done an ‘09 196 (no ballast) and access to the rudder end is clear through trunk floor. No need to touch the tank.
The rack cable goes in/out from the front, it’s no fun getting the ram through the conduit. Especially with the engine shoehorned into the bilge. Much bigger pita than the older rotary cables.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shea.95 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 1:17pm
@TRBenj what do you mean that "the rack cable goes in/out from the front, it’s no fun getting the ram through the conduit"?
Thank you,
Andrew
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bri892001 Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 2:14pm
The ram is the part that moves the rudder.
That portion of it is not flexible at all, so it's a little trickier to maneuver that part of it.
Going out through the front vs. the back, your two options are to:
A.) pull the whole cable out and feed the new back in from the stern/rudder side
or
B.) pull the whole cable out and feed the new back in from the helm/front side.
The front portion has the rack assembly, and that is even bulkier than the ran, so you really don't want to have to have to feed that through the belly of the boat. So, you want to do it from the front so that you are feeding the ram side of the cable through.
You usually use rope or cable to follow out the old cable as you pull it out, so you have a way to pull the new back in. When you're feeding it back in try to make the knot/connection with your rope as streamlined as possible. You can use some duct tape or similar to help smooth this. You don't want the knot getting snagged on a anything on the way through. Definitely have the motorbox out of the boat, because you want to be able to easily reach to feed it through the bilge. This is also where your helper comes in. One person can be tugging or pushing, while the other person kind of helps with snags and obstructions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 2:18pm
The (rack and pinion style) cable (as opposed to a cable for the rotary system) has to go in and out from the front- as the rack end won’t fit through the conduit that connects the helm to the bilge. That means the cable ram (rudder end) - which is 12-14” and NOT flexible - has to go through that conduit instead. Not fun.
On the older rotary system cables, the ram end is the harder end (helm end is flexible) so they could be pulled out and then installed back in from the rear, rather than the front. Much easier.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH20SKIER Quote  Post ReplyReply Direct Link To This Post Posted: June-07-2018 at 5:18pm
I did mine ('05 206) and it was a bit of a pain.   I cannot recall if the 196 has the trunk but if so you will need to clear / remove the contents and floor in order to gain access to rudder and cable mount. For me the mount was halfway under the fuel tank and had to be accessed from both the trunk side and from within the boat. This was the single most problematic part of the installation -
Good Luck
