  New Posts New Posts RSS Feed - manifold temp
manifold temp
fredo68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Topic: manifold temp
    Posted: August-02-2006 at 9:47am
after 40 min ride last night seemed to be running little warm, port side exhast manifold almost 50 degrees hotter. what?
fredo68
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2006 at 9:51am
Have you had an impeller go bad on you lately? Sounds like you have some pieces clogging the water passeges/hoses on that side preventing adequate cooling.
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: August-02-2006 at 4:37pm
It depends on the plumbing setup. When my thermostat opens, most of the water exiting the manifold will go out the driver side exhaust. The raw pump is on the passenger side and the T is close to the exhaust manifold on that side (for water cooling exhaust on both sides) and the water flow is crossing the thermo housing toward the driver side. I noticed this several years ago when winterizing my boat on a cool day. I noticed alot more steam on the driver side when the thermostat opened. And like he said, you could have some impellor parts stuck in the manifold, you should notice less water coming out.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 9:46am
tim your engine and mine are identical.
i got the impeller after you told me how
to read the number off the back of the pump,
just been to busy to do it. so this weekend ill be changing the impeller and flushing out the hoses.
thanks and when you winterize do you run pink antifreeze through?
fredo68
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: August-03-2006 at 5:15pm
No, I use the green stuff. I always crank it with the fake-a-lake in the driveway before I take it to the lake. While you're checking the hoses, take the thermostat out and look at the end of the bypass fitting that's to the left behind the thermostat housing. It has a 90 degree in it and I've found impellor pieces stuck in that thing twice.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote fredo68 Quote  Post ReplyReply Direct Link To This Post Posted: August-04-2006 at 9:17am
very good.thank you sir.
fredo68
