2001 timing ? |
jbussell2001
Newbie Joined: May-31-2006 Location: United States Status: Offline Points: 8 |
Posted: August-20-2006 at 3:30pm |
what is the factory setting on my boat?i need some help my boat seems slugish and has loss of power my distibutor has not been moved. if i can put a timing lite and dwell the dist..thanks
marks
Groupie Joined: April-23-2004 Location: United States Status: Offline Points: 96 |
If the engine is a 351, it is 10 degrees BTC at 600 RPM. It should advance to 30 degrees as you rev the engine.
Checking your timing is a good start. If you haven't changed your fuel filter/separator you might want to do that too. FYI, there is a PCM Engine manual in the reference section of this web site. |
