  New Posts New Posts RSS Feed - Pulsing then complete loss of fuel
Watarski View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Watarski Quote  Post ReplyReply Direct Link To This Post Topic: Pulsing then complete loss of fuel
    Posted: June-16-2019 at 11:55am
I have a 1985 2001 that I've restored over the years. A few years ago Jody at FLInboards helped me put a model year 2001 GT-40 motor in the boat because of a block issue on the original 351. The motor has been solid, but the past year I've been chasing a fuel issue. Actually I had an issue with the lower fuel pump a few years back - pieced it back together with spare internal parts.
I took the boat to Jody the last time the below happened (September '18) - caveat: This was pre-Hurricane Michael and the boat hasn't been out since September as a result of the damage to the area. Jody cleaned out the tank and lines, fuel system, etc and verified that it was working, putting only non-ethanol fuel back in (3 gallons). I took the boat to the landing with a fresh battery and it fired right up. Took it back out and filled up with more non-ethanol fuel and took it back to the lake. The problem is, it started fine, idled fine. As soon as I start moving/giving gas it starts pulsing every second or two - almost like air pockets in the lines. I pulled the kids around on the tube for about 45 minutes at ~15 mph and it progressively started getting worse / more frequent. Because I was worried we'd get stranded, and I wanted to see if it was bad gas - I loaded them up and started heading back to the dock. Got the boat (slowly) up to 30mph, pulsing the whole way, and stronger more frequent until about 15 seconds in, it shut-off and wouldn't start back. Temps were fine the entire time (replaced impeller in Sept before I took it to Jody). I've had issues in the past a couple years back with the lower fuel pump as I believe there are plastic pieces that spin around and can break apart. What I noticed yesterday as I was trying to pull the plug, was that the upper black canister (not sure official name) where the fuel filter sits inside was really hot. Leaned up against it and it got my attention quick! I'm not sure where to start troubleshooting, all I know is it's a fuel issue (I think). Any ideas / opinions / starting points are much appreciated!
1985 Ski Nautique 2001
Post Options Post Options   Thanks (0) Thanks(0)   Quote gun-driver Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2019 at 12:21pm
Sounds like your pieced together low pressure fuel pump isn’t working correctly and starving the high pressure pump inside the FCC (canister)
You could start by using a fuel pressure gauge on the fuel line to see what’s actually happening with the pressure when it acts up, but I feel pretty confident that if you replaced the low pressure pump your fuel starvation problem will be solved.
audiodude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote audiodude Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2019 at 2:12pm
I have a 1989 2001. I have had with my boat running great then all of a sudden it will slow down and start to die. I thought it was a coil issue so I replaced the coil and the boat ran fine, problem solved , I thought. Next time I took it out started doing the same thing. I removed the anti siphon valve and found some dirt in it cleaned it up and the boat ran fine. Then the last time I took it out skiied a bit and was ready for another run when the boat wouldn't start and then when it finally did it would only idle any attempt to give it some throttle would cause the boat to die. I removed the the anti siphon valve and it was clean so I moved on to the carburater primary bowl and found some dirt in one of the inlets cleaned that up and the boat ran fine. Not sure if this long winded explanation will help and I'm not sure i've actually fixed the problem. Time will tell.
2000 Ski Nautique 1989 Correct Craft 2001
In the words of Milton Berle: "You can lead a man to Congress but you can't make him think"
tryathlete View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryathlete Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2019 at 6:59pm
Could be the little plastic line inside the HP pump or as you say more likely the LPP. Audiodude also picked a good one in the anti-siphon valve. I went through all of these when I got the Super Sport. Some I did preventatively (HPP and plastic tube); others out of necessity as indicated by the pressure gauge.
The good thing is you’ll be good to go for a long time when you’re finished. That’s got to be a very fast 2001 when it’s running right.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-16-2019 at 7:21pm
Here's the kit Peter mentioned that replaces the plastic tube.
FCC HP pump repair kit
