PCM 302 PCV valve |
77stang
Senior Member Joined: May-19-2004 Location: United States Status: Offline Points: 342 |
Posted: September-16-2006 at 1:08pm |
I would appreciate some part numbers for anyone who has replaced the valve.
I'm having a hard time finding the correct replacement. The part number on mine is ACC801 and i've been unable to cross reference it. NAPA although very helpful couldnt do it either. Thanks alot, Jerry |
79nautique
all PVC valves are pretty much the same all you have to match up is the diameter for the base where it goes in the valve cover and the vaccum hose of the current one. Most likely the hose fitting is going to be undersized so just use a hose clamp on it.
77stang
thanks 79,your contributions are always appreciated.
