  New Posts New Posts RSS Feed - '82 ski nautique dash switches
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Topic: '82 ski nautique dash switches
    Posted: September-02-2019 at 7:15pm
4 in a column to the left of helm.
What does the second from top do?
Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2019 at 10:47pm
Thanks
It turns something on and off
Click on the link below and it'll tell you what, assuming the switches are drawn in order which they should be since I think it was a CC diagram. Looks like it's for the bilge pump to me
It'll be a handy thing to have anyways.
it's from some planet named Nautique
Post Options Post Options   Thanks (0) Thanks(0)   Quote MourningWood Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2019 at 11:18pm
Those aliens. Sometimes I find their language so hard to decipher.....
in this case the diagram shows 3 switches...all functions of which I can account for. My '82 has 4. The label is too worn to make out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-02-2019 at 11:22pm
They count differently too
These are the push button breaker type switches right?
In order from the top
Nav
Pump
Blower
Ignition
Then again I think I can see what you're saying too
I guess somebody sitting in an 82 wil have to tell you
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 8:56am
Here's a link to an 82 for sale
The dashboard picture shows the switches
If you blow it up to 500% it shows the labeling on the switches pretty clearly
But...................just like your boat, the second switch down isn't labeled
Since it's at Watercraft Sales in Three Lakes WI maybe you could get Pete to wander over and do a little investigating
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 9:05am
And here's a link to a thread that talks about that same switch and fuse setup
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 11:37am
I have a good idea about that 82. If it's the one I'm thinking of, it's been for sale for a few years. It doesn't show up on Watercrafts used inventory so it may be under consignment? Note the tannin staining on the hull sides. It's been sitting pretty low in the water for awhile! I think it's on the verge of a part out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 12:07pm
Both my former 84 and my neighbors 84 had/have the same unlabeled switch (2nd from the top). I don’t recall if it was used for an accessory. I know some early BFN’s got 2 bilge pumps (mine had separate switches), though the 2nd was to the right of the wheel. Only nav/pump/blower on the left of my 79.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-04-2019 at 3:03pm
I suppose it would be relatively easy to crawl under and see if anything is hooked to the switch
