Pros and cons of electric ignition |
mlegassey ![]() Newbie ![]() Joined: April-15-2020 Location: Maine Status: Offline Points: 36 |
![]() ![]() ![]() ![]() ![]() Posted: April-29-2020 at 9:12pm |
Considering getting rid of the old points and condenser and buying electronic ignition kit. Does anybody have any advice on the matter?
Barefoot maniac
If you do go with a EI conversion and you boat long distances, I'd keep a spare module on board just in case of a failure. The EI's have gotten reliable through the years but they still can fail. Are you expecting any gains?
Orlando76 ![]() Grand Poobah ![]() ![]() Joined: May-21-2013 Location: Mount Dora, FL Status: Offline Points: 3108 |
I wouldn’t necessarily go spend money to convert just for the sake of converting, no real gain. I see pros of points and I agree. But when was the last time we seen a failed EI module on this site? 🦗 🦗
Wonder what happened to that other post
KENO ![]() Grand Poobah ![]() Joined: June-06-2004 Location: United States Status: Offline Points: 11189 |
You must mean the one from Chuckactor I just got the popcorn ready too ![]() ![]() |
Yea I was going to ask him if he's changing over to coil on plug because you know not many cars are sold with distributors anymore. Then I was thinking how about direct injection every ones going to that as well. But then I thought aw nuts I'm just going to drop 265K + and get a new Paragon it's even got linc and navigation on it- everyones going to that anyway
Duane in Indy ![]() Platinum Member ![]() ![]() Joined: October-26-2015 Location: Indiana Status: Offline Points: 1578 |
Oh boy, what a can of worms you have spilled open.
I run MSD distributors and electronic boxes on my Mustang 17 and all my hot rods. They shine the most on start ups, but are also great at high rpm. You will hear pro's and con's about both systems. There is no correct answer, just do what you want The control box can be hidden if you prefer, Not a big fan of the conversion units but I have used a Pertronix module with no ill effects. |
1978 Mustang (modified) |
67 ski nat ![]() Platinum Member ![]() Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1199 |
Gassey You stepped in it.
The answer is do both I love my pertronix billet on the 318, And I had my original prestolite rebuilt, really glad to have it and know it is ready I’m saving my stimulus check for a spare module |
Hahaha love stirring a turd when I can. I bought an 85 nautique in Conn. for 1,000 bucks and trucked it back home to Northern Maine and the boat starts like crap. Installed new plugs new wires, cleaned points made sure all grounds and connections were clean metal and it still starts like crap, it’s getting fuel, I just would like to try something new and try the electronic ignition. But I’m sure if I buy new contacts and a new cap I’m sure it will last a very long time. Caught in the middle
Barefoot maniac
Jonny Quest ![]() Grand Poobah ![]() ![]() Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 3009 |
3 words: Davis Unified Ignition.
You can dump the coil along with the points and condenser. JQ |
Nautiquehunter ![]() Platinum Member ![]() ![]() Joined: December-31-2008 Location: Lake Lanier GA Status: Offline Points: 1010 |
The Davis Unified Ignition is an old school HEI system ben around for decades very reliable very simple to install . I run HEI on all my 351's
You talked me into it I like the sounds of it!
Barefoot maniac
Maybe that first sentence should say "starting a turd when I can" since it starts like crap ![]() Why not spend a little on the tuneup parts and make sure it starts and runs good first, instead of just assuming an electronic ignition will cure all your issues? Then get the electronic after that |
Also check compression. If low, spending big $ on a new dizzy won't solve anything.
Matthew,
Do you know how to set dwell on a point set? Lots of youtube's out there if not. |
For sure you probably have other problems other than distributor
Clean carb? Plugs/wires. New gas |
I guess I should pull the carb apart and give it a new cleaning next
Barefoot maniac
Tim D ![]() Grand Poobah ![]() Joined: August-23-2004 Location: United States Status: Offline Points: 2641 |
One thing I can tell you about EI conversion is, if the distributor cap cracks it can fry the module inside.
Tim D
chuckactor ![]() Senior Member ![]() Joined: August-20-2013 Location: Ft Collins CO Status: Offline Points: 102 |
Ugh.. I'm back. I hate points. OK, I said it.
Pete:
That was a good video in the link. Dude is a mechanic and not real comfortable in front of a camera! JQ |
This one is kinda funny:
https://jalopnik.com/points-ignition-lovers-are-they-misinformed-or-mini-5343502 |
So basically your saying points are unreliable and you come to this conclusion because you found someones opinion that matches your view on the internet using an example of a neglected Lucas distributor made by an English company known for questionable electrical equipment ? Can you then explain the continued use of points in general aviation? One would think reliability would be important in that field. I'm sure there are a few here that could show you failed electronic systems going by the trade name of Pro Tec
