  New Posts New Posts RSS Feed - Fuses
Fuses
Stuckers Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Fuses
    Posted: May-19-2020 at 8:35pm
I have a 1994 sport nautique is there a fuse anywhere on the boat that would blow in keeping the boat from starting. I have the on off switch in the back of the boat and that is on.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2020 at 9:44pm
Starting or cranking?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stuckers Nautique Quote  Post ReplyReply Direct Link To This Post Posted: May-19-2020 at 10:50pm
Starting it will not do anything tried to jump battery but it did nothing
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: May-20-2020 at 9:10pm
Mike,
Still a little confused. Just to confirm, "starting" is getting the engine to run and "cranking" is the starter is engaged and turning the engine over.
You have voltage at the battery? Cables and battery terminals nice and clean and tight? One item that will prevent cranking is the NSS (neutral safety switch). It's on the trans so I suggest checking it for continuity.
