  New Posts New Posts RSS Feed - Greasable Rudder?  2003 Nautique 216 SE
dkimball View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkimball Quote  Post ReplyReply Direct Link To This Post Topic: Greasable Rudder? 2003 Nautique 216 SE
    Posted: May-26-2020 at 10:44am
While getting the boat ready for the year I noticed that the steering needed a little budge to free up after sitting for the winter. It turns OK now so I am thinking it is more in the rudder than the cable. Does anyone know if the rudder has a grease zerk in a 2003 2016 SE? I haven't had the back seat out because well everything I have read says it is a pain and I haven't really figured out how to get it out and get to the rudder. I have the hard tanks and it is pretty tight in the trunk area. I have had the boat for 3 years and replaced all of the hoses, belts, plugs, wires, cap, rotor, thermostat as it only had 175 hours when I purchased it (actually blew holes in two hoses while footing so they were pretty rotten from sitting).
Whether it has a grease fitting or not can anyone give me the run down on removing the back seat so I can get the floor section up to get to the rudder. I am sure I will be changing the cable in the future anyway.. Thanks.
Kimball
quinner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote quinner Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 12:03pm
Should be a remote zerk in the trunk mounted to the lifting ring threaded rod, may be a plastic cover in front of it
Post Options Post Options   Thanks (0) Thanks(0)   Quote dkimball Quote  Post ReplyReply Direct Link To This Post Posted: May-26-2020 at 12:21pm
Thanks Quinner I will check it out this weekend when I am back at the lake.
Kimball
