  New Posts New Posts RSS Feed - light pole repair
light pole repair
kman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kman Quote  Post ReplyReply Direct Link To This Post Topic: light pole repair
    Posted: June-03-2020 at 1:56pm
Rear light pole. Any idea how to fix this? I'm not sure soldering would work would it?
Kirk
1976 Southwind 20
Eagle Mountain Lake Fort Worth
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2020 at 2:53pm
Kirk,
The head should come off the pole. This should give you enough room to spice in some more wire. Use some good adhesive lined heat shrink butt splices. If not, then the bottom socket needs to come off. Then take a look at the bulb socket to see and remove the contacts. They need the old wire drilled out so you can solder in the new wires It's ether that or look for a new/old Perko on ebay.
kman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kman Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2020 at 2:58pm
Gotcha. I think I can do that... Thanks!
Kirk
1976 Southwind 20
