What distributor do I have ? |
HzSandman
Groupie Joined: February-14-2009 Location: Australia Status: Offline Points: 45 |
Posted: June-23-2020 at 9:46am |
Hi ladies & gents,
I'm back working on my 1981 SN project after leaving it for 8 years in the shed! I'm ordering some tune up parts from the USA (am in Australia) and wanting to make sure I get the right distributor cap and rotor button for my setup. I believe I have a presolite clip down cap with electronic ignition ? Could somebody please confirm ? What rotor and plug leads do I need ? Thanks :) |
phatsat67
Grand Poobah Joined: March-13-2006 Location: Indiana Status: Online Points: 6151 |
That would be the prestolite clip down cap 86 and earlier with a PCM electronic ignition conversion installed. That’s a much better quality EI conversion vs a flamethrower and likely only bested by a DUI.
You need to put a few drops of lubricant oil down the center of the shaft you can see in the photo. (Felt pad and is yearly maintenance). Also rotate the engine around by hand until you see the weight slides and put some oil on each of those as well (there are two). |
HzSandman
gun-driver
I believe I have a copy of the instructions for that conversion kit.
HzSandman
Thanks for the info and tips phatsat67.
if you do gun-driver could you please email me a copy ? (if electronic version) |
