Pylon and steering wheel |
wsavini
Senior Member Joined: September-06-2012 Location: Taunton, Ma. Status: Offline Points: 282 |
Posted: August-15-2020 at 9:02pm |
Looking for a pylon with the ring/finger for a 83 BN. And a steering wheel for a early 70’s CC Mustang
Bigbirdmk
Newbie Joined: January-28-2018 Location: Columbia Status: Offline Points: 24 |
I have a pylon with ring and finger out of a 79 Ski if your still looking.
1979 Ski Nautique Excalibur 330 repower
wsavini
I’m interested, Please send me pic?
Bigbirdmk
I cannot figure out how to post pics on here. Do you have another method I can send them via?
Bigbirdmk
They should be visible on the classic correctcraft Facebook page. |
wsavini
You can email me wsavini@gmail.com
Or text me at 508-649-3449 |
wsavini
Ok I just figured it out and saw pic. That’s what I’m looking for. How much should I send you?
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21169 |
Not to throw a wrench in anyone’s sale but I’m assuming dimensions were exchanged? (The SN and BFN pylons do not generally interchange).
wsavini
Well that’s good to know. The one in my BF seems to be bigger in diameter than my sn. I’ll check it out. My BF pylon ring was cut off with a metal saw.
Pylon diameter is the same for all cc’s since ‘76 (2.5”). The height is different- the critical difference between SN and BFN is the distance from the hull cup to the pylon flange (BFN is taller- a flanged SN pylon will hit the floor and never reach the hull).
Ring and finger are obviously the same though- you could swap that piece over. |
wsavini
I’ll measure from the bottom of the pylon to the floor plate.
wsavini
Good call! Thank you. BN is 14” from bottom to floor plate. The SN is 9”. Thank you
ScottZ
Platinum Member Joined: January-20-2004 Location: Clanton, AL Status: Offline Points: 1154 |
I have a pylon out of an 88 Barefoot Nautique. It is the first year of the new design with the ball in place of the ring and finger.
Lake Mitchell , AL 1984 Ski Nautique 1972 Skier |
wsavini
Can you Pm me a price? And pic?
wsavini
Please send me a pic and a price. Ty
ScottZ
$200 I will get a picture of it later this week.
Not to throw another wrench but you can’t swap ring/finger pylons with ball toppers without some modifications. The hull cup is a different size- the r/f pylons had a small finger installed at the bottom (~1” diameter) that installed in a corresponding sized hull cup. The ball top pylons retain their full diameter right to the bottom and used a 2.5”+ diameter hull cup.
Additionally, a 83 BFN will not have a cradle and will require a flange at the floor (and a backing plate underneath) to secure. The flanges were removed from the pylons when the cradles showed up (‘85 or 86 on the Bfn) which was a few years before the ball topper style came out (mid 87). So no ball topper will have the required flange for the boat in question. Trying to find a flanged Bfn pylon will likely prove tricky… they would have been used 79-85ish and is specific to that model. If your pylon is otherwise ok, you might be best served swapping over a ring and finger as that is a lot more common (used across all models 73-87). |
wsavini
Man I do t know what I’d do without you guys. Ty for that info.
