  New Posts New Posts RSS Feed - Steam coming out of exhaust
todicus View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Topic: Steam coming out of exhaust
    Posted: October-04-2006 at 12:23pm
I noticed last time I had my boat out, some steam was coming out of the exhaust...... not a whole lot, but noticable. It was a warm day with warm water temps, boat ran fine at a constant 160 degrees.
I read some old posts about potential problems, but was hoping this is just a normal thing for the EFI GT-40 with 200 hrs on it.
Living outside the wake
95GT-40SNOB
Tim D View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 12:56pm
On cooler days, you'll notice some steam when the thermostat opens. If the humidity is just right, it may be more noticeable.
Tim D
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 1:09pm
Yep, A few occasional puffs probably not an issue, one particular side spewing out steady steam then your probably looking at a cracked manifold or something of the like...
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 2:44pm
Cracked intake or exhaust manifold ?
95GT-40SNOB
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 2:59pm
Duh..... exhaust......... where do they usually crack ?
95GT-40SNOB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 3:22pm
Water travels through the walls of the exhaust. Look at the gasket below. The thin slots on each side is where water travels. The large opening in the middle is where the exhaust is. All it takes is a crack in the wall for water to enter.
Tim D
Post Options Post Options   Thanks (0) Thanks(0)   Quote todicus Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 4:01pm
Thanks Tim. Could it be a cracked gasket ? Do they sell them at SkiDim ?
95GT-40SNOB
Post Options Post Options   Thanks (0) Thanks(0)   Quote TRBenj Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 5:11pm
A cracked riser gasket could let water back into the head, so if you have any signs of it leaking, replace it! Im positive SkiDIM sells them.
Steam coming out of the exhaust can be perfectly normal though- we get it all the time on all of our boats, especially in the morning.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim D Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 5:20pm
I took that pic from skidims site. Like trbenj said, if it's cool enough, you'll have steam constant, from the water heating up from cooling off the exhaust manifolds. If you have a crack and it's leaking into the motor, a sign would be hard to start after short shut down.
Tim D
M3Fan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote M3Fan Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 5:38pm
The early 90's boats are steam machines. Not unusual. If you had a leaking riser gasket, you'd be in some serious trouble pretty quick I'd imagine.
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: October-04-2006 at 11:54pm
I am happy when steam comes out of mine. It tells me my thermostat is open.
So, where do you get the gaskets for Ford / Interceptor exhaust manifolds? They look like the one in TimD's pic but the SkiDIM site says those are for Ford and GM Indmar whatever that is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2006 at 12:12am
I never found them Jim had to make some with the exacto knife.. hope you do better
Joe.
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2006 at 1:04am
I had to make my last set too. Exacto knife was the tool of choice - and a set of hole punches. Did you notice how the openings on the machined fits on the exhaust manifolds are not exact? I actually had to make each gasket special for each fit. What a pain. Know what I mean?
bkhallpass View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bkhallpass Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2006 at 1:19am
Not sure if you were being facetious, but I'll bite. Indmar is just another inboard engine manufacturer like PCM. Has been the engine of choice for Mastercraft for many years, and is the standard engine offered in Malibu. BKH
Livin' the Dream
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2006 at 9:47am
Thanks BKH. I have seen the Indmar name around. I just didn't know what it was.
Barracuda View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Barracuda Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2006 at 2:57pm
Had some steam the other night- was running the engine with the hood up and noticed the steam coming out from all around the exhaust manifolds-
Shut the hood and don't think about it.
-Brad
Nautique2001 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nautique2001 Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2006 at 3:42pm
I thought the steam was normal to some extent? Mine will occasionally blow out a burst of steam, but clear up after a while. All my exhaust stuff is brand new. Would water, engine or air temp vary the steam? I'm not going to sweat it. I occasionally blow off steam after work and I feel fine.
Ken
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: October-05-2006 at 7:29pm
I'm with Brad.
eric lavine View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote eric lavine Quote  Post ReplyReply Direct Link To This Post Posted: October-06-2006 at 9:00pm
they use those gaskets many different engines, you can get them at napa, tell them you need there sierra catalog. even your local mercruiser dealer should have them on the shelf.
87BFN owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2006 at 5:25pm
steam on my boat is normal if it's less the 65 degrees out. I have had experience with excess steam on a MC before. The gasket had gone bad and it plug the water pa$$ages. Luckily we found problem right away. It was a friend of my parents boat. So we went to the hardware store bought gasket material and made a new one. Took maybe a half hour.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 87BFN owner Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2006 at 5:27pm
oh yeah make sure you are getting plenty of water with the steam though, if there is a lack of water then, you have a problem, sorry forgot to mention that.
The Dude View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote The Dude Quote  Post ReplyReply Direct Link To This Post Posted: October-17-2006 at 6:52pm
steam is cool...like James Dean.
Mullet Free since 93
95 Sport
