Engine stumble at High RPM |
AlfaDon
Senior Member Joined: September-18-2011 Location: San Leandro, Ca Status: Offline Points: 392 |
Posted: September-18-2020 at 1:38am |
On the lake today trying out a spare prop I’ve had for a while. Trying to find top speed/rpm. It’s a older 3 blade OJ 14 x 16. Plus the 422 was singing so I decided to give it a try.
Flat lake, 5000’ elevation. I’m running the RPMs up and up. When I get to about 5700, it stumbles and I back off the throttle. It felt like an electronic cut out only because it was quick and sharp. Either the stern came up a bit or the nose dropped slightly. 48 mph on the GPS. I just confirmed the tach reading with a cheap laser. Any ideas? I always thought the end of the power band would just stop accelerating. Was it a prop issue? It was pretty rough running. I’m going to put the 422 back on tomorrow and see what the numbers are. |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3335 |
5700, it's Valve float likely
River Rat to Mole |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10719 |
Maybe a little bit of info on the engine and what's inside it and bolted onto it would be helpful
AlfaDon
Thanks.
I should add this to my diary Stock crank and rods. New pistons, Ported Aluminum heads w/ 2.02/160 valves running 10.5/1 compression, Hyd roller cam and lifters .550 lift, about 230 duration both I & E. New Comp springs to match. Edelbrock Performer Intake manifold 650 CFM Quickfuel Carb, DUI Dizzy |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21131 |
5700rpm and 48mph with that prop don’t make any sense... some of your numbers are wrong or your prop should’ve been retired a long time ago.
AlfaDon
Yep. It’s a prop I got cheap as a backup. It’s officially been determined that it’s junk. I now have a Nibral candle holder or wall ornament.
GottaSki
heh, hot motor..forgot that
River Rat to Mole |
