How open 160 Thermostat |
Tbarile
Groupie Joined: May-10-2020 Location: Indiana Status: Offline Points: 55 |
Posted: September-21-2020 at 2:01pm |
I've been having problems with my 02 196 Ford GT40 running at 180. I bought the boat in the spring and the old T-stat was rusted out so I ordered a new one from Nautique parts. My boat has been running at 180 ever since and most suggested there was an air leak somewhere. I checked all hoses, etc.. and couldn't really find anything. Yesterday the impeller burnt up and while removing all the pieces I decided to pull the t-stat and check it. I dropped it in 160 degree water and it didn't open. I bumped it to 180 and it barely opened, I then went to 200 and it fully opened. My question is how much should it have been open at 160? I've emailed Nautique parts with a pic to see if maybe they screwed up or I just got a bad t-stat.
Jonny Quest
Grand Poobah Joined: August-20-2013 Location: Utah--via Texas Status: Offline Points: 2995 |
Well, that doesn’t sound right. I tested my 160 t-stat and it opened fully at 165 degrees (based on IR thermometer). If yours doesn’t fully open until 200 sounds, that gets my Spidey-Sense tingling. Is your thermometer reading correctly? If so, you way want to consider a replacement.
Tbarile
Yes my thermometer is correct. I would post pic but don’t appear to be smart enough!
67 ski nat
Platinum Member Joined: July-19-2018 Location: Santa rosa Status: Offline Points: 1194 |
Your IQ must be higher than thermostat number to post pics
We really do not allow any pictures |
Right at the top in the forum general discussion section there's a sticky post by Keith.
Here's how to post pictures: |
Tbarile
I should have been more clear. I can figure it out on my laptop but my phone (where the pic is) doesn't show the same options for some reason. The entire line starting with the scissors doesn't exist and I was too lazy to email to myself, save, etc...
Yes, mobile devices are a problem.
67 ski nat
I was joking of course. But my laptop went blue screen last year so I only have phone now. I’m jealous
Tbarile
Well I bought a new t-stat and did a side by side test with my old t-stat and it appears that a 160 degree thermostat barely opens at 180. The old and new t-stat were identical and only opened maybe an 1/8'. |
