Loose transmission mount bolt - composite stringer |
2001Sunsport
Groupie Joined: October-07-2015 Location: MI Status: Offline Points: 86 |
Posted: February-25-2021 at 10:47am |
Anyone ever repair a transmission mount bolt that isn't biting in a all composite boat? I know this is a issue with wood stringers, but couldn't find much for composite boats.
Swapped from a PCM trans to BW Velvet drive and it moved the mounts back just a bit. Seems that one of the bolts either stripped the hole or doesn't have enough to bite into. Suggestions? Only fix I can think of is adding glass.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10734 |
Seems like if you added glass like you said, you'd be OK.
I think I'd fill it with a gnarly mix of epoxy and fibers, strands etc. and redrill it
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5312 |
No need to mix and fill a syringe for injection.
2001Sunsport
Thanks all! That thickened epoxy adhesive looks like it might be the trick.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21134 |
What type of “composite boat” are we talking? It would be helpful to know so we can give proper advice, considering how it is built.
Doesn’t sound like a correct craft to me, their use of aluminum engine cradles (with through bolted engine mounts - not lagged) predated the change to composite by quite a bit. Tell us more about what’s really going on here. (I would have guessed Malibu based on the screen name but they didn’t use PCM transmissions and their stringers are hollow...) |
You should have guessed Supra
It's not necessarily a Sunsport, but it's a Supra
2001Sunsport
It's a misfit 1995 Supra Comp TS6M. |
Well look at that
I’ve owned several wood stringer supras a but not familiar with the composite construction... let’s see some pics of the configuration.
2001Sunsport
Here are some I had on the computer
2001Sunsport
I wouldn’t expect them to be hollow based on those pics. They really don’t look any different than the wood cored version I am familiar with. More likely a low strength core material that won’t bite (foam etc)? Or maybe there’s a backer in there? Not likely but possible. Stick something down the hole and see what you can dig out?
What are you doing with the 1.23 that you removed? |
Go to the "not exactly a link" below for some reading |
Interesting reading and pics but that appears to be from ~10yrs later than the boat in question. The in-process stringer pics do not appear to be utilizing the same construction methods, at least from what I can see.
It was a 1 to 1 PCM 40i that he removed It's tough to see much in his pictures and the Skiers Choice pictures
Ah, indeed.
2001Sunsport
Yea, I rebuilt the PCM that came out, but it wouldn't engage forward gear, when warmed up, unless the engine RPM was raised to about 900. Linkage and cables adjusted right and working fine. Shifted into forward fine when cold. So replaced with the BW. (the PCM was full of water at some point before the rebuild and warped the clutches so they were more or less locked forward)
Now it's sitting in the shed as a emergency backup in case the BW ever blows. |
2001 Sunsport If you click on the link below you'll find the 93 Waterski Mag buyers guide with some description of the stringer setup in 2 different places Page 42 in an ad, and later on page 143 when talking about the "misfit" Same basic setup as the later stringers referenced earlier today Foam filled glass stringers with composite 'stuff" glassed in where the mounting hardware screws in to give something strong to grip. Your 95 won't be different than the 93 description or the later one either For anybody else.........good reading about the 93 boats from all the ski boat companies regardless of what brand somebody may or may not be biased towards
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1739 |
Thanks for the link and the trip down memory lane Keno!
If there's any demand for some other "trips", I could link the same buyers guide from 87, 89, 90, 96, 98, 01, 02, 03 later on today I'd probably put them all in a different new thread for ease of finding them.
2001Sunsport
Thanks Keno, that link is great. Appreciate all the info everyone!
