  New Posts New Posts RSS Feed - Retrofitting Speedos
NeilMcG View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Topic: Retrofitting Speedos
    Posted: January-30-2022 at 3:04pm
Has anyone heard of using old Airguides as a housing for new speedos?
Saw a post on FB where someone said they removed the inner mechanism and flush mounted a new GPS.
Mille1sj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mille1sj Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2022 at 4:04pm
I sent my 1977 Speedo to nauticlaugic to be retrofit with a gps. They removed the internals and replaced them with a gps. Looks original but works perfect.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2022 at 5:05pm
I'll take a look. Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-30-2022 at 5:38pm
Here's a link to your original speedometer thread.
The Nauticlogic conversion was mentioned early in the thread, (second post) but you weren't interested.
It's the same thing that was just mentioned.by Mille1sj
Post Options Post Options   Thanks (0) Thanks(0)   Quote NeilMcG Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2022 at 7:14am
My apologies if I broke forum etiquette by starting a new thread... I have zero experience in this area I did become completely confused after seeing a post from a different site.
I actually did examine the Nauticlaugic option, but was unwilling to do the retrofit because it cost more than the boat is currently worth. I was seeking experience from anyone who's taken another speedo and successfully stuffed it in a hollowed-out airguide.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: January-31-2022 at 7:57am
I wouldn't worry about etiquette around here Wink
I was just pointing out that you already shot down the Nauticlogic option in the other thread. Can't really blame you for not wanting to spend more than the boat's worth.
Your Airguides can most likely be fixed to stop that "fountain effect" that you have if you don't care if you have GPS or not.
