Gas fill cap |
swilliams
Senior Member Joined: June-26-2016 Location: Cincinnati,Ohio Status: Offline Points: 235 |
Posted: April-16-2022 at 4:48pm |
I could use an original deck fill gas cap. PO used one that doesn’t fit well. To fit a 76’ Martinique. It is the cap that has the raised tabs. I believe it to be an Attwood original deck fill. Thanks!
1976 Martinique,350 Omc. 1975 Glastron/Carlson CV16,115 Merc.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10701 |
Since you bought one a while ago from Nautique parts that didn't fit the hole in your deck, do you know the hole size?
Here's a link to an Attwood fill assembly from Great Lakes Skipper that fits a hole size of 1 3/4 inches with more rounded tabs or.........here's a Sea-Dog from Go2Marine with the tabs shaped like the CC cap back then, but no hole size dimension Do you need just the cap or the whole assembly?
swilliams
Just a cap. I’ll check those out but I hate buying stuff that doesn’t fit. I thought I would check here first to see if anyone had one they could part with. Thanks Ken.
swilliams
Bump
woodyelc
Senior Member Joined: February-17-2004 Location: orlando Status: Offline Points: 376 |
You will find there no replacement cap for the fuel fill. Need to replace unit complete
woodyelc
swilliams
Hoping someone here would have a spare.
swilliams
To the top.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21125 |
I don’t think anyone can say with any degree of confidence that the cap they have will fit your fill. I’ve seen mismatched ones of the same exact style fail to fit properly- I don’t know if it’s production variation or what.
Your best bet is to buy a complete fill as advised above. |
Is somebody named Steve still looking for a gas cap (and filler assembly) ?
If you are, click on the EBAY link below and you'll find something that'll maybe have somewhat of a chance of threading into your filler or you could swap the whole assembly. |
fanofccfan
Platinum Member Joined: December-13-2009 Location: North Bend NE Status: Offline Points: 1729 |
I think his name was Bill. 🤷🏻♂️ the 24 hour courtesy rule expired and I bought it. Thanks Keno! I hope it matches what I have. I lost the original and had to go to my parts box for a replacement and that one already had a tab broken off so hopefully the new one with two tabs should help with opening.
fanofccfan
I will offer it up again if it doesn’t fit my application.
fanofccfan
Now I am second guessing myself for not waiting for Steve to respond. I may have gone out of order. If that is the case I will offer it up whether it fits my application or not. I don’t want to be “that guy”. Steve just let me know if you still need it and it’s yours.
DenDen
Senior Member Joined: July-20-2023 Location: USA Status: Offline Points: 177 |
Den
There are piles of gas caps for sale out there that are close but don't have the same threads Nautiqueparts sells one that's in that category. It's an aftermarket cap and filler assembly that works as long as the person is willing to do a little extra work and replace the whole assembly and not just take the new cap and screw it into the old filler neck. Plenty of others out there at a cheaper price than the one mentioned above from Nautiqueparts The one that Bill bought probably has at best a 50/50 chance of screwing right in I stumbled into it because I bought a gauge panel from a 70's boat that had gauges, switches and labels that are the same as a mid to late 70's Ski Nautique at a "pretty cheap " price and looking at his other listings afterward, the gas cap was there. Using some convoluted, twisted logic I figured it probably came from the same boat and maybe it would fit. And Bill...........I'm glad somebody here on CCF took a chance and bought it It seemed like an appropriate wait |
And here's another for somebody named ___________ (fill in the blank) to take a chance on
It's a bit pricier
fanofccfan
Whew!! I will rest easy now knowing my waiting period was appropriate. I will report back on fit when I give it a try.
fanofccfan
That looks very similar as well. I will wait on this one for while longer.
swilliams
Thanks for thinking of me and yes I’m still looking. The one on eBay does seem a bit pricey but it’s only money, right?
samudj01
Gold Member Joined: March-10-2009 Location: NC Status: Offline Points: 946 |
Someone Posted some parts from a 1972 CC on Facebook in the Classic Correct Craft Boats forum...there is a complete gas fill and cap
swilliams
Thanks, I’ll look at that.
fanofccfan
Well. The gas cap that arrived looks nothing like the picture on the eBay ad. It does however look like the one referenced in DenDen’s post. I sent seller a message and am patiently waiting for a response.
Well right about now Steve's probably glad you bought that good deal
fanofccfan
Ha! Yep! the guy did say he will send me my money back. We will see if that happens. On another note....does anyone need a newer style gas port and cap?
