Coil options |
brantb
Groupie Joined: May-15-2019 Location: Colorado Status: Offline Points: 94 |
Posted: June-21-2022 at 8:02pm |
Last year my boat stopped starting. In the attempt I let the magic smoke out of the starter, so that is already being replaced.
Tried to order a DUI, but they were delayed more than their site said so had to cancel. Now looking to just replace the coil and throw a jumper wire to the I terminal as well. What is my best option for a coil? 99 air tique, 351w ford standard rotation. |
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11112 |
I'm guessing you have the original Prestolite electronic module in the distributor.
If that's the case, any cheap 1.5 ohm coil will work just fine. A BWD E70 coil or a cross reference to it works. Or ask at the parts place for a coil for a 67 Ford Mustang with a 289, Or you could spend a bunch more doe some super duper super high voltage coil that won't make it run any better. Somebody might ask how you know the coil is the culprit and not the module itself
Since you were looking for a DUI distributor, here's a link to a recent thread by CBR dude.
He bought a knockoff for 140 plus shipping from AAA Marine link to thread link to distributor at AAA marine Make sure you read all the info especially the part that says the Sun Distributor Machine is NOT INCLUDED Just passing this along, I don't have any experience with this distributor
brantb
KENO, as always you come through with a good response. I read the thread and it seems to be very similar symptoms. Going to order the one linked and some new wires.
Hopefully it gets there in time or i will be picking up a new coil or whatever else i need to to get this things going. Have 2 and a half weeks of vacation and want to spend a majority of that time on the boat.
The boat is currently at my dads in WI, so guess a timing light will be flying with me in a couple weeks. |
How about when you get the distributor, you post some pictures of it showing the vent screen(s), one with the cap off showing the block off where the vacuum advance was removed and the gear.
I'd compare it to your old gear to make sure it's cast iron and not machined steel Iron on the left, steel on the right |
brantb
I didn't take enough photos, but 100% recommended the company above. They shipped it out quick and it was great quality. It took me a bit to get it retimed because I messed up two of plug wires and was fighting myself for a few hours.
Once I get on my computer I will post the couple photos I have |
Hey look at that.................an actual review of the AAA distributor and some pictures to follow
