Quick drain oil hose |
NeilMcG
Senior Member Joined: September-20-2021 Location: Pittsburgh, PA Status: Offline Points: 228 |
Posted: June-27-2022 at 9:25pm |
Anyone have experience fabricating a DIY oil drain hose? One would think the attachments are basic plumbing fittings, but I'm not sure of bolt/pipe thread relationships so i looked quite comical at home depot ~dazed and confused.
Neil...otherwise known as "Bellagio Boy" (thanks Keno.) |
MourningWood
Gold Member Joined: June-13-2014 Location: NorCal Status: Offline Points: 915 |
Well... the 'banjo' fitting that sandwiches between the drain hole in the oil pan and the adapter bolt could be a bit tricky...
I should think that for $45 you can buy a complete kit (from Discount Inboard Marine). Maybe easier...
'I measured twice, cut three times, and it's still too short!" |
NeilMcG
Thanks. That's probably what I'll end up doing. Eliminate the headaches too.
gun-driver
Neil,
I have one I can part with.
NeilMcG
You're the man!
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11029 |
That could also just be BB for short..............and you're welcome You might as well get the one from "the man" Your 78 will have 1/2-20 threads in the oil pan and in the mid 80's Ford changed to M14x1.5 metric threads, so make sure his kit has the right threads or you might still be dazed and confused if it was for his 85 SN, you should be in luck.
gun-driver
Yea it’s from the ‘85, I’m pretty sure it’s 1/2 x 20 UNF.
I know the GT-40’s are 14 x.1.5, I’ll check it when I get home and scrounge it out of my parts supply.
NeilMcG
Big shout out to Gun Driver for turning me on to Fumoto's oil petcock drain plug. It's the best solution for oil changes I've ever seen.
Thanks Paul Fumoto.com |
