Transmission seal leak? |
ultrarunner
Posted: July-31-2022 at 8:08am |
Getting a slow drip when static. Transmission seal?
Mpost
Senior Member Joined: July-05-2018 Location: Monticello, MN Status: Offline Points: 323 |
? is that dripping white or mixing with water in the bilge???? Water in the oil making it overfull?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10652 |
Looks to me like it was kinda emulsified before it leaked out of the transmission like Mpost suggested.
+2 when my case gasket let go it was nice red oil there no strawberry shake
ultrarunner
Nice and red on the dipstick. I think a bit of residual water in that groove in bilge. I guess I'm pulling the trans. this fall :-(
Fl Inboards
Grand Poobah Joined: January-20-2008 Location: United States Status: Offline Points: 2065 |
Pretty easy? check your trans fluid/oil level. provide water engine cooling source, start engine bring to temp. shut off engine. Grab clean white rag, and lay it flat under bell housing in the bilge, Front transmission seal / engine rear main seal area . Take second white rag lay flat under transmission tail housing, Rear transmission seal. Take third rag lay flat under oil pan drain kit fixture. Take third white rag and wipe all the high pressure fluid hose connectors, check for fresh fluid. Go have beer, or what ever for an hour or so. Come back check rags and assess info on rags..
pjsmoreno
Senior Member Joined: April-25-2016 Location: Liberty, Mo Status: Offline Points: 161 |
Mine was nice and red when my front seal leak a few years back.....not strawberry color on the bilge.
Maybe you have some emulsified engine oil dripping out of the engine
A leak doesn't make that milkshake appearance unless it was coming out already looking like a milkshake. Take a little oil or ATF and drip it into a little water, it won't look like your picture unless you shake it up pretty good to get it mixed.
ultrarunner
Yeah, this is strange. I'll get a few towels down and check the fittings. Dipstick oil is nice and clean.
