Hella Relay for GT40 |
jhersey29
Senior Member Joined: February-20-2014 Location: Colorado Status: Offline Points: 272 |
Posted: August-01-2022 at 7:31pm |
In Canada on vacation. Looking for the Hella relays for a GT40. We at the Lake Of Bays. Fuel circuit is not working, no power at the low pressure fuel pump. Jumped the emergency cut off switch and still no power at LPFP. Anyone have 1 or 2 relays close by?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 11119 |
Maybe some parts store close by has an Echlin AR-174 relay or a Standard Motor products RY141 relay or 2 or something that cross references to it.
if they need an automotive reference................1990 Caddy Fleetwood Brougham blower motor relay You need a good ECM relay and a good pump relay to get power to the pumps, but you probably know that already. |
jhersey29
We found the relays. The local marina was able to transfer them from another location in Canada. Ended up being the 50 amp fuse. I just removed that wiring and did the retro fit to remove it.
