  New Posts New Posts RSS Feed - Water pump not sucking
Tbarile View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbarile Quote  Post ReplyReply Direct Link To This Post Topic: Water pump not sucking
    Posted: September-06-2022 at 10:23am
I have an 02 ski Nautique with the GT40. Went to ski this morning and boat overheated. Immediately assumed it was the impeller but when I took the pump apart the impeller was in great shape. Reinstalled and it’s still not sucking water. I’ve check hoses and all seem right. What am I missing?
Thanks
desertskier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertskier Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2022 at 10:50am
I had an impeller failure recently.  The impeller looked fine but the bonding between the rubber and the metal hub had failed so the impeller wasn't spinning just the hub.  A few other members have experienced this failure also.  Otherwise you may have an air leak between the pump and the pickup.  Do a forum search.  Lot's of cooling system info on this site.
92 SN - Owned since 93
99 Pro Air
89 SN - Went to live on a lake in Texas
75 Donzi 16 - Sold in 93
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: September-06-2022 at 2:10pm
Hook a hose from your pump suction to a 5 gallon bucket of water on the floor of the boat and start the engine.
You'll know very shortly after that if the pump is working.Wink
It pumps roughly 5 gallons/minute at idle
It'll at least tell you if the problem is pump related or is an air leak or blockage before the pump
