Stringer Replacement 86 Silver Nautique. |
Post Reply | Page <1 234 |
andrewmarani
Senior Member Joined: May-31-2005 Location: Baltimore, MD Status: Offline Points: 217 |
Need some carpet suggestions. I did some searches and turned up https://marinecarpeting.com. Anyone buy carpet from someplace they like? Looks like 20 oz is standard. Depending on cost any reason not to go to 24 oz?
They also have Shaw indoor outdoor carpeting. That's a manufacturer subs i work with use on job sites. I might be able to buy that from a sub I know and get a better price. Anyone work with Shaw? Previous searches turned up DAP Weldwood All Weather Outdoor Carpet Adhesive to glue it down. anyone have pros or cons? Thanks Andrew |
Builder
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Online Points: 21132 |
Interesting. IMO, any path that allows water to drain also allows water to enter… I have thoughts on which I think is more likely!
16-20oz carpet would have been original. The thicker the carpet, the more plush it feels, and the more water it holds. |
andrewmarani
Picture shows a test fit of the two front sections of floor with the driver’s seat in place and the fit around the installed battery box. I needed to check where my feet landed when sitting in the seat to make sure my size 13's missed the vent tubes and other pipes i will discuss shortly. I won't have the airbox with it's sloping footrest so I also needed to locate a footrest I will make from some old mahogany gym bleacher wood I have laying around. I will epoxy some stainless T nuts into the Coosa floor so the footrest is removable.
When this thing is done, removing two bolts from the observers seat base and two bolts from the foot rest will give under the bow deck access like you see in the picture. I've spent enough time under there over the years to want easy, clear access. Even the drivers seat has T nuts and machine screws holding it down and can be pulled, though that's more complicated.
Builder
andrewmarani
Originally the wire harness, speed tubes, steering and throttle cables and the bilge pump tube all ran in one pipe from engine to the bow. I’ve broken those into individual pipe chases for ease of repairs in the future, creating the need for some creative pipe bending using heat. And lots of different holes in the bow floor and that bulkhead behind the battery box. The steering cable has a 16” stainless bar on the end so the 2” pipe has two very light bends in it so the pipe can turn up through the bow floor and still allow the bar to slide through. At this point, all the flooring is cut and fit. With all the Coosa in place, I have a nice flat floor with only the pylon interrupting it. Next step is to test fit the carpet I bought while nothing is in the way. |
Builder
andrewmarani
Bought 8’-6” wide carpet and tested it in the boat today. Not ready to install, still need to finish epoxying the floor down and install the foam. I was worried the 8’-6” wide carpet wouldn’t be wide enough to run up the sides but that turned out fine. I was hoping to be able to wrap the carpet up the sides without cutting. I think that would work starting at the back and getting about halfway to the front of the boat but after that the curve and flair of the side is going to create folds, so that plan is out. I’m going to have to cut it at the floor to side transition like was done originally. I was going to trim the carpet to fit today but I think it will work better if I glue the carpet down to maybe 6” from the sides, leave the last 6” loose and then cut it at the floor to side transition. Nothing moves during or after the cutting that way. The original carpet trim strips are definitely not made for a 90 degree turn up the sides, CC just kind of made it work. If I reuse them I think I need to actually turn the side carpet out onto the floor a half inch or so to get it under the trim strip so the carpet doesn’t ravel. The floor carpet then slips into the trim on the other side. Does anyone have a source for a carpet trim strip that’s designed for a floor to side transition? Seems like a normal detail and there should be a trim piece for the 90 degree transition. |
Builder
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10726 |
On those year boats like yours, with rotary helms, you don't need to pull that 16 inch bar forward and around any corners to get the cable out. You remove it by pulling it out of the support tube at the back disconnecting the cable at the helm, taping a rope about 20 ft long or so and a plastic bag around the cable at the front end and pulling it out from the rear. Going back in, you tape the new cable end to the rope that's in the tube and pull it forward with the rope. The big awkward rear end never has to go around any sharp bends In the condition you're in right now, snake a rope through for when it's time to pull the cable through. If it was rack and pinion steering, then it's a different story
Not following your thoughts on the carpet trim. Walls should be cut at the floor, the trim sits up almost 1/2” and will cover that edge no problem. Floor should be cut 1/2-1” away from the wall so it tucks cleanly into the trim channel.
andrewmarani
The trim that came with the boat is a 1/2" thick, maybe a touch more and sits flat on the floor. There's no spot to tuck the side carpet into it unless I turn the side carpet out onto the floor a half inch or so.
See the picture above. left side is where the floor carpet tucks into the trim. Right side goes against the side of the boat and tapers down to less than a 1/4" and is designed for carpet to tuck under it. I spent sometime on line looking at boat carpet trim and nothing is designed for a floor to side transition, don't really see boats with carpet on the sides much at all. I did find some trim that matches the old trim in the picture above, so if I need to go that route I will likely buy new stuff since it should be more flexible than the very stiff stuff I took off the boat. A picture of a relatively new Nautique showing how they currently handle that trim would be nice. Assuming CC still runs carpet up the sides of the boat. Thanks Andrew
Builder
Nothing really tucks under from the wall carpet. Not sure why this is so confusing. It’s been several years since cc has been putting carpet in boats- not sure what you’d hope to learn. They used the trim in question at least ‘80-09, should still be available to buy from Nautique parts and others. Not exactly a mystery.
andrewmarani
It's not difficult to solve, I can definitely make it work. it's just frustrating to me that something that's actually designed for this issue isn't available, I can be a bit ocd about details. I will turn the side carpet onto the floor a half inch to get it under that lip on the right side in the picture so it doesn't ravel.
The trim originally used on the boat and the one at Nautique Parts are designed for a carpet to VCT floor transition, flooring subcontractors we work with use it all the time. FYI a 12' length on Nautique Parts is $83. Same stuff in a choice of colors is $23 on line. |
Builder
andrewmarani
Ordered a sample of this stuff by Trim-Lok. Might work a bit better plus I like the included 3M adhesive tape.
EDIT: OK, bought a foot of it and I'm not impressed. The vertical section will cover a bit under a 1/4" of the side carpet, which works fine. The floor side will catch about 1/16" of the floor carpet, which is never going to work, there's no way i'm going to be able to cut the floor carpet that neatly. So NOT using this stuff.
Builder
Faceplant
Senior Member Joined: July-27-2013 Location: Otter Lake , Mi Status: Offline Points: 406 |
Please keep us posted. I might be interested also.
1980SN2001
Groupie Joined: August-01-2022 Location: Rocklin, CA Status: Offline Points: 96 |
I also used something like what your holding in the picture at the transition from floor to wall. I got it from tools4flooring.com and it was called Burke 153.
https://www.tools4flooring.com/burke-153-3-8-black-cerco-bar-12-length.html |
andrewmarani
I cannot figure out why half the time the picture rotates 90 degrees when I upload it. Bow flooring is epoxied down and all the tubes/pipes/vents installed, which you can see in the photo. I’ve test fitted the engine frame. Needed some sanding on the stringers to get it in place, ending with a good snug fit. Leaving an 1/8” more between the main stringers would have made life easier. Originally the frame was lagged down from the top but I’m going to run bolts through the sides, seems more secure. As a side note: I put the notches in the stringers to match the original, including the locations of the notches for the engine mount bolts. This was a mistake, the front engine mount bolt notches are much longer than needed and the back notches too tight. I have way too much space on the front notches and I had to sand out and then re-glass the front part of the back notches to get a bit more clearance for those bolts. In addition, the front of all the notches are sloped, for no reason I can discern. Better plan is to make the notches run about 1 ½” past the bolt locations in the engine frame and make the ends of the notches vertical with rounded corners at the bottom and top of the vertical cuts. I will go back and edit my posting on the stringer layout. I’m using fairing compound (pale green stuff in picture) to smooth out the bilge prior to using a TotalBoat bilge paint on it. Doesn't show in the picture but i used west systems faring compound to make a flowable fill and filled in a weird ditch in the bilge right against the transom (roughly 3/4" deep, 8" long and 1" wide running along the transom, no idea why it was there) and a water puddling spot between the rudder post and the reinforced area for the shaft log. Once the bilge is painted, I will install the engine frame, then finish installing the floor, finish foaming and install the carpet. Then I can have the marine repair shop where the engine is stored drop it into place on the frame. Figure I’ve got 3 to 4 weeks before I can get the engine installed. I try not to think too much about all the stuff left to do before summer and concentrate just on the next couple of steps… |
Builder
How are you uploading pictures to the site? Are you using the CCF upload feature or something else?
andrewmarani
i'm using the forum picture uploader. Looking back at my pictures it looks like the forum wants them to be wider than they are tall. When I upload a picture taken from that aspect, it doesn't rotate. When I upload a picture that's more tall than wide, it rotates it. Not really a big deal, was just a puzzle.
Builder
Once upon a time you uploaded a picture of your boat using IMGBB (back in the "Elephant" thread).so I know you can do it
I guess for some reason you went back to the site process which isn't any better than it ever was and it was always a bit challenging just to put it in nice terms. Ever since using IMGBB, I haven't had any pictures rotate when posting And it's easier to do and works no matter what you're posting from. I could go on but you must have your reasons for wanting to use the site process and make everybody look at sideways pictures and get a sore neck . |
The stringer notches under the motor mounts are larger on the engine side in order to accomodate either engine option (Chevy mounts are several inches further forward than Ford Windsor).
The gentle angles are easier to glass, and therefore stronger. The larger than needed notches also make it easier to get a hand or wrench on the back side of those motor mount bolts. |
andrewmarani
I'm planning to replace the original mufflers, I repaired one years ago for a small burn through hole and I think the other has a hole now. Not a hard fix but after 38 years probably time for new mufflers. I've found two options though I expect there are more out there. Thoughts on the choices below?
Centek Verna Ski-3 in 45 Degree Inlet. Dimensions work and it has a 45 degree inlet which will make life much easier with the exhaust piping. No need to force that hard bend into the heavy rubber pipe. Anyone have any experience with Centek?
Other option is from SKIDIM, whom I trust far more than Amazon. Basically the same design but 50% more in cost. Ultra Marine. |
Builder
Centek made the Inverta-Flow mufflers that were found on many of the "slant back" Nautiques. I would have no problem using a Centek product.
You've had experience with Centek mufflers all these years in your boat without knowing it. That's what it came with. I'd rather buy the Centek mufflers from the outfit on Amazon, than pay the big price differential for the Ultra Marine mufflers fron SkiDim Centec has been around almost as long as you've been around. They're 62 years old If you for whatever reason don't trust Amazon, google the same Centek part number (1000216) and you'll find a variety of places and prices
andrewmarani
SKIDIM has double checked my order several times in the past and called me to fix my order mistake for my model boat or engine. Always liked them.
But I will go with Centek on amazon this time around and save the dollars. I'm good buying from Amazon as long as i'm sure I'm buying the right product. Thanks for the feedback. One more thing off that long but getting shorter list. One more coat of bilge paint tomorrow and I can bolt in the engine frame this weekend!!
Builder
The Amazon profile for Atlantic Boat Supply, the Amazon seller, says that they're located at 17 Peckham Drive, Bristol Rhode Island and Google says that's also the address for Jamestown Distributors, so I'd say you're dealing with a reputable outfit
andrewmarani
Ordered the Centek mufflers, should have them next week.
Spent some time researching carpet adhesive since that's coming up soon. Looks like Henry 263 is preferred but that's not available around here due to environmental regulations even through one of my carpet subcontractors. Henry 663 has good reviews as well so that's what I'm going to use. Picture below is the painted bilge. Next up install the engine frame, which will take hardly any time, then more flooring installation. |
Builder
