Engine vibration |
SGY1 ![]() Newbie ![]() Joined: October-31-2006 Status: Offline Points: 21 |
![]() ![]() ![]() ![]() ![]() Posted: October-31-2006 at 2:01pm |
Guys. I have a 2005 196 with the Excalibur motor. I've had the boat since May, and since May I've noticed a weird vibration when pulling skier up and when slowing down. I checked the usual things--alignment, prop, prop shaft, prop strut. Even got a new ACME prop and a new strut. Still the vibration persists. So, I took the boat into my trusted mechanic--expecting him to tell me nothing is wrong, just my imagination.
Wrong. He just called. They ran the boat up and felt a definite vibration in the motor as well as a heard a troubling noise. The motor has only 230 hours on it and runs great--except for the vibration which is unusual and never experienced before on my three previous Nautiques. My mech wants to dig into the motor to find out what's wrong. He says its only going to get worse. The motor is under warranty and he's PCM authorized. My mech has been doing this work for over 30 years and builds drag boat motors. He's pretty trustworthy. What do you guys think? |
bkhallpass ![]() Grand Poobah ![]() ![]() Joined: March-29-2005 Location: United States Status: Offline Points: 4723 |
SGY,
I have no data on the boat motor, but my neighbor experienced the same problem on his chevy truck. A vibration at certain RPMs, which persisted. Chevy pulled the motor and tried to put a sleeve in one of the cylinders. It didn't work so they ended up replacing the motor under warranty. I'd have to ask him what the exact diagnosis was. BKH |
Livin' the Dream
Thanks BKH. I'm going to have the mech do a compression check, a fuel pressure check and make sure there are no engine codes.
I don't like the sound of a new sleeve. |
79nautique ![]() Grand Poobah ![]() ![]() Joined: January-27-2004 Location: United States Status: Offline Points: 7872 |
it might be as something as simple a dampner plate being bad, but if it's under warrenty then it won't cost you any cash regardless of what's wrong.
M3Fan ![]() Grand Poobah ![]() ![]() Joined: October-22-2005 Location: United States Status: Offline Points: 3185 |
SGY, welcome to CC Fan! Finally came over from PN, huh?
Thanks M3Fan. I've lurked here for a while--even registered before but couldn't remember my pa$$word or registration name. Gettin' old I guess.
I still read the happenings on PN. But, not much over there interests me. Lots of wakeboard talk--not much in terms of skiing anymore. I have nothing against wakeboarding, but I'm pa$$ionate about skiing. And, everyone over on PN that knows anything mechanically is also here on CCFan. I suspected I'd get quicker info over here. Thanks to all who's replied so far. |
Good to have you on board. Great group of people here- you'll have to get to the next reunion.
JEFF KOSTIS ![]() Gold Member ![]() Joined: April-19-2005 Location: United States Status: Offline Points: 817 |
I know that my new engine in my 76 Mustang has some strange vibrations. I know that if you run it in neutral at about 1000 rpm, it shakes on the mounts, especially if the exhaust gets hit with a wave. The engine is a 2004, and is identical to the excalibur except it has a intake for a holley. I do know that our 74 Mustang (identical boat) has the OMC 225 hp 307 Chev, and that is as smooth as ever!!
Do they have a poor balance in those new engines??? Curious... Jeff.... |
eric lavine ![]() Grand Poobah ![]() Joined: August-13-2006 Location: United States Status: Offline Points: 13413 |
once in a while the harmonic balance will go bad on the engine and will cause a vibration, who knows thank god its under warranty, would hate to end paying for that one especially if the problem was mis-diagnosed, hopefully they'll drop a new one in there for you
Hey SGY, saw my buddy last night. The problem he had with the engine in his Chevy truck is that one of the cylinders was out of round. FWIW. BKH
Livin' the Dream
Thanks BKH. Hopefully its not something like that. If so, I would hope PCM/CC would replace the motor.
I a$$ume a compression check would be indicative of such a problem--more leak down in the out of round cylinder?? |
a compression test is the first thing i would do after visual inspection, I have a chevy at my shop that dropped a valve seat after 50 hours from new. alot of speculation on what was wrong with it from other shops, simply did a compression test then pulled the head on that bank with the problem cylinder, of course the engine had to be replaced. if you need a engine there is a guy in detroit that sells them brand NEW merc engines(same thing, roller motor) for $2499.00 they come with all the sheet metal, harmonic balance, and waterpump. you dont have to buy it just giving a guideline on what you should pay in case you have to dip into your Christmas fund oops sorry.... holiday fund
Thanks Eric. Fortunately, the motor is under warranty. Richard at Skidim.com told me that faulty valve seats are the first thing they see go on these motors--but only if they are relatively new. Mine has over 230 hours on it. So, we'll see. What kinds of things was the motor doing that dropped a valve seat?
Well i doubt it is an engine related item otherwise you would feel the vibration all of the time but since it is while pulling a skier or slowing only then it has to be in the drive line, bent shaft, loose bushings worn dampner plate, loose coupling.
Valve seats, harmonic balancer, piston problems will be constant not occasional and will only get worse as the RPM increases. |
Valve seats, harmonic balancer, piston problems will be constant not occasional and will only get worse as the RPM increases. then again that is a$$uming you are diagnoising it correctly or discriping it correctly. |
hopefully as 79 said he doubts it is not engine related and if diagnosed properly with vibrations you go to the driveline first and once ruled out then to the motor you go.. if he does find the problem hopefully you scuffed some sand and maybe you have a prop problem, more times than none ive looked at props and thought they were fine, and guess what??? but with a prop or shaft the vibrations will come and go and dont rule it out
I wish it were that easy. But, I've been through the entire drive line. Replaced prop and balanced new Acme. Put in a new strut and had the alignment triple checked. Also had the shaft checked. The mechanic disconnected the prop shaft and ran the motor up. The vibration starts at about 2400 rpm and gets more prominent the higher the revs. There's also an incriminating noise in the front of the motor that is in harmony with the vibration.
replace the harmonic balancer and see if it goes away.
How tough a job is that? Also, if it is the HB, what damage has been done to my crank and main bearing due to the torque vibration?
it's not that hard you need to looseen and remove the belts, remove the lower pulley three-four bolts, remove the bolt holding on the balancer then using a puller to pull it off. Then put on the new one using a rubber mallet or deadblow hammer, bolting up the pulley and tightening the belts.
While it's off check the front seal and replace if needed. as far as damage it might have out of rounded a bearing or two depending on how bad it vibrated and for how long but the damage is already done so you might as well use it until it goes the rest of the way which could be quite a long time or a short period of time depend on it's severity. |
Thanks 79. When you say a bearing or two, what are you talking about? The rod bearings? Are there rod bearings on the rod ends connecting to the crank journals? Any damage to the crank possible?
send me your address, ill give you one because im curious or call me at my shop i have a couple of spares that are close to new, dont buy one, you'll only be waisting your doe if it dont work. You can visually inspect the harmonic balance, look if it is twisted or made fine rubber powder around it and so on
Thanks Eric. That's a very generous offer. I'm supposed to hear more today on what they think is going on. I'll keep you posted.
SteveY ![]() Newbie ![]() Joined: September-02-2006 Location: United States Status: Offline Points: 4 |
Just want to say thanks to everyone for their help. This is a great site.
Got a call from my mechanic on Friday. Before digging around in the motor, he decided to change the plugs and cap and rotor. After that, the vibration was gone! I looked at the cap and rotor and I've seen worse. The plugs looked weird. I changed the plugs in July with the factory recommended platinum plugs. The July plugs had a green tint where the boot goes and green around the electrode. They looked alot more worn comparing them with the factor plugs that I took out in July. Anyway, went skiing yesterday and for the first time, the boat ran without vibration for two sets. At times this summer, I would pull a skier for a set and the vibration would be gone and then come back during the second set. So, I'm not ready to declare victory yet but I think I'm close. |
Hey, I guess I just figured out my other log in. SGY1 and SteveY are the same dork.
Glad to see its fixed, but some girls like the ride of a Harley/Nautique. You might of had a winner!!!
![]() Jeff... |
The Dude ![]() Platinum Member ![]() ![]() Joined: October-19-2004 Location: Houston Status: Offline Points: 1335 |
Great news Steve. Glad you're on it. Sure seems like a weird fix though.
Mostly I'm glad to hear someone out there is still skiing. You'll have to post some pics... |
that's becuae it was discriped as a vibration instead of a engine missfire/rough idle issue. |
Dude, where are you located? I'm in the Denver area. Water is getting fairly cold. We pulled the course last weekend and now are just free skiing for excercise.
Thanks to everyone who provided helpful advice. I just wish it were July again. |
