Finally got a slip, no lift yet-bilge question |
gravyleg pirate
Groupie Joined: August-01-2012 Location: Lawrence, KS Status: Offline Points: 61 |
Posted: May-08-2023 at 6:22pm |
So we finally got a slip at our local marina but there is no lift yet and may be a while before one comes available. I don't want to leave her in the water but think we're going to try it. After poking around it seems that the most problems arise from gelcoat blisters that form, however I haven't gotten an answer yet on the bilge pump question.
Will it need to have water pumped out while sitting there? If so, is my bilge pump wired so that the master battery switch won't disable it? How do I check? 2005 SV211 for reference |
GLP
"If we couldn't laugh we would all go insane" 2000 Air Nautique 216 (for 19 years) 2005 Air Nautique SV211 (2 months and counting...) |
Grand Poobah Joined: June-06-2004 Location: United States Status: Online Points: 10644 |
Here's a link to the owners manual for your boat
You'll find what you're looking for on page 4-41 and 4-43 Since the boat's been around for 18 years, somebody may have changed things, so I'd probably test the auto bilge pump with the boat on the trailer to verify that it still functions as built. Have the boat sitting at about the same angle that it sits in the water Start filling the bilge with a garden hose and verify that the pump starts with the master disconnect switch in OFF, bilge pump switch in Bilge Only Gel coat has gotten better over the years and a 2005 boat shouldn't have any issues living in the water all summer
gravyleg pirate
I've played with that automatic switch before and I wonder if it has been rewired sometime prior to me. I have never used the garden hose test on it though but will definitely do so. Just printed out the manual so I have a hard copy. Thanks for the link!
GLP
Morfoot
Grand Poobah Joined: February-06-2004 Location: South Lanier Status: Offline Points: 5311 |
Just a thought.... If the boat gets some Sunshine (maybe the stern) then think about getting a Solar trickle charger. Why not use the sun to keep the battery fresh. I've got one for mine that sits on the lift that doesn't get used too often. I think i paid around $25 for one off Amazon. So Far so good.
storm34
A healthy coat of Collonites 925 marine wax will help keep things fresh. I'd also recommend you plan to pull the boat every few weeks to clean the bottom.
gravyleg pirate
Already not looking forward to lying on my back polishing the bottom!
Without looking are the solar chargers big enough now to run a trickle and a small fan for ventilation? When we're done for the day there will surely be some wetness that needs to evaporate. At home I have a box fan that I throw in for a couple of days to ensure it's dry, but at the dock I'm not certain that is the best idea.
GLP
Click on the link and pick something. The sun's pretty powerful, it should be able to power a battery trickle charger and a solar fan at the same time. Fixed the bad original link Do you have a cover that breathes naturally like Sunbrella for example?
bwinn
Senior Member Joined: July-13-2009 Location: ct Status: Offline Points: 391 |
Link no work |
gravyleg pirate
yes, we have a nice cover as far I can tell, it does have two vents over the windshield area. I'm just worried that there isn't enough air movement with the passive evaporation. I'm probably overthinking it as Kansas is very windy in the summer!
GLP
peglegtoo
Newbie Joined: July-09-2018 Location: Mass Status: Offline Points: 16 |
First year with a new to me boat the bilge pump failed on mooring. It had a fair amount of water in it by the time it was discovered as I had not been to it in a couple weeks. I replaced that pump and added a 2nd one on its own switch and fuse and outfall hose. I also run a small solar panel to compensate for the bilge occasionally running and keeping the battery topped off. it has worked great.
gravyleg pirate
Any chance you have a photo of where you wired it in? I have a couple of guys who are handy with car electronics, but always appreciate people who have done it successfully!
GLP
63 Skier
Grand Poobah Joined: October-06-2006 Location: Concord, NH Status: Offline Points: 4232 |
That's pretty much the perfect setup for a boat on a mooring, dual bilge pumps and a trickle charge to keep batteries fresh. |
