  New Posts New Posts RSS Feed - Can't find brand name
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Topic: Can't find brand name
    Posted: May-16-2023 at 9:11pm
A while back in a thread (probably a year ago & believe it was a new member stringer job) another member posted a few pictures of 1 of the boats he owns.
This particular boat has a molded insert glued onto the hull.
said insert is the stringers, bulkeads etc and what was very interesting was the fact that there is a water box above the strut, so the packing gland is in the box instead of the hull bottom.
The owner also posted some brochure pics as well.
I googled and searched for three days with no luck,
I'm wanting a bowrider and there some older 80's ish ski boats like supra, brendella etc that are in the condition and price range needing a full rebuild.
Broad stroke of my plan for world domination is (from the transom forward) building a 2 into 1 all bi axial glass stringer set up.
So from the transom forward, minimum width for shaft & steering, 45 out to engine cradle width then just forward the front engine mounts, 45 inwards into 1 stringer running to the bow eye, the single stringer would likely punch thru so the pylon could get mounted to it (like a 4 way stop but 2 come in on a 45)
Not a whole mold or liner type insert like the other members boat i'm asking about, just 1 stringer mold, (approx 3 inches wide) pop out a part scribe to fit just like wooden stringers,bonded together into desired shape- ie 2 into1 and glassed in place.
No bulkheads in between, maybe 2 or 3 per side outboard the 2 into1 stringer for floor stiffness, have to get that far first.
Seat boxes and 45's front and back the engine should help with strenght/stiffness
Floor pan with glass seat boxes driver, observer & split rear bench if walk thru transom, gas tank not sure yet, depends on hull brand and if possible or not.
It's a work in progress idea subject to mods as needed.
Got a couple pages of notes, measurements etc off the 79 nautique and the same similar hull would make a great candidate because, again, the hull is layed up really nice and strong, but another brand is the answer on this.
Thanks guys for any help finding that thread and pics to help the brainstorming.
Late edit in after all the spelling corrections, the outward 45's behind the engine could i guess come together into a V between the stringers and notched/ holesawed for whatever it interfered with since that V would likely add torsional strength.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 67 ski nat Quote  Post ReplyReply Direct Link To This Post Posted: May-16-2023 at 11:02pm
#perfectscreename
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2023 at 6:10am
Maybe A Look In the Below thread would be Useful     Wink
And it's got a link to his  Ball of Spray thread with a bunch of pictures missing.
Malibu calls the stringer system FIBecs  and the box around the shaft HDS (hydrophonic dampening system)
GottaSki View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GottaSki Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2023 at 7:02am
Yeah, BOS moved, and every picture on the site evaporated 😕
River Rat to Mole
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2023 at 10:29am
Thank you, you guus know yoir stuff for sure.
Malibu ! I've been thru dozens of manufactures pages, forums, rebuild threads, pictures, you tube resto's etc etc, there wasn't 1 word about it.
First google search today, hydrophonic, google fills in the rest i click and takes me to a malibu forum about the waterbox, been typing waterbox and every other combo coming up with nothing.
Really appreciate the help and knowledge base on ccfan.
Thank you.
I'm also having zero luck posting pics, read the post but don't speak computer.
Site even let me copy and paste it from another site like it used too.
Post Options Post Options   Thanks (1) Thanks(1)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2023 at 12:28pm
Did you watch the video about posting pictures (last post on 2/7/23)  along with the word description ?
Here it is again Wink
Originally posted by Mpost Mpost wrote:
Originally posted by 75 Tique 75 Tique wrote:
Per Ken's request/suggestion, and per Ken's efforts in finding a relatively easy way to post photos, here is a step by step process.
1.  Have photos you want to post in your phone gallery or on your computer.
2.  Open website imgbb.com
(no need to sign in, sign up, or register unless you want to)
3. click or tap on "select images to upload"
4. Go to your gallery or computer and select photo(s)
(Leave autodelete option on "dont delete")
5. click or tap "Upload"
6.  In the "Embed codes" box, scroll to and select  "BBCode full linked"
7. in the box at the bottom of the page where the photo URL shows up,  tap or click "copy"
8. Open your CCF reply and tap and paste or click and paste.
9. Voila, its there. (Note: it wont show up until you view preview or post it)
I suppose 8 steps sounds like a lot, but its mostly quick easy point and clicks (or taps)  Goes quickly and easily.  Give it a try.
Added this here so it is sticky or pinned Smile
And added this link to the You Tube video that Larry made so there are written instructions and a video showing how to do it.
Written and video instructions all in one spot Wink
Good idea Marty
Post Options Post Options   Thanks (1) Thanks(1)   Quote Riley Quote  Post ReplyReply Direct Link To This Post Posted: May-17-2023 at 4:22pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: May-18-2023 at 5:18am
Thanks guys, and i'll give those instructions a try.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2023 at 7:49pm
Somebody on here ski'd behind one of these things. Neighbors on the huron river where i grew up had one back in the early 70's. It sounded funny (whined in reverse i think).
Seen a few on youtube converted to v8 merc outdrive and another to berkley jet pump.
I'd gut one of these johnson hulls and on the very cheap install a ski boat driveline in one just to see what it did while the ski boat hull was going thru new stringers etc.
I'd have the material on hand and it does have a flat bottom w/ the tracking strakes running right down the hull
Faceplant View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Faceplant Quote  Post ReplyReply Direct Link To This Post Posted: July-03-2023 at 9:52pm
My parents had one of these wile growing up. Skied behind it but was still a newbie. Remember that we used to get quite a few looksie loos from people.  Was a very cool boat though .
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: July-04-2023 at 2:19pm
For sure a cool boat, it's 180 all the cookie cutters out there how could ya not want one. problem is all the 60's 70's hulls that would make great direct drive conversions are far and few between.
The 79 i had was 700 bucks on the trailer.
I know theres another one out there (ski boat) and some member drives by it everyday.
Sooner or later word will make it to them i'm looking.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: July-26-2023 at 12:13pm
i'd appreciate some input on these boats and if there is another year/brand/model i'd like to hear about those as well
i'm over fit and finish, won't spend that money. more interested in;
quality of running gear ?
how does it ski ?
how big of a hit does the slalom wake take between the boomerang and mobius as an example since they are currently listed for sale?
feel free to explain that difference on any brand you know about.
bowrider? i want it for loading/launching as much as the 2 extra seats [company] but are there drawbacks ?
 [adding a rear pylon/ski eye for fun skiing/tubing is in the plan so rear seating isn't lost when friends/family are on board] main pylon stays in place.
what else ?
right now these are listed around lake norman
94 prostar 190 8,900
94 moomba boomerang 9,500
94 brendella pro comp 4,500
99 moomba mobius open bow 12,000
95 brendella sport comp open bow 8,5
there is a mid 90 malibu near my home in the 10 range but i'm looking out of town were ski boats are more prevelant, [or where would you look].
there are a handfull of supra ts6m but they have kevlar in the laminate and if it needed stringers, repairing kevlar is above my ability.
i don't mind a long weekend drive,seatrial for the right boat.
what say you?
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: August-17-2023 at 7:54pm
So heres a 93 nautique up in nc for 6k, it needs engine work to begin with.
The thermostat housing that bypasses water to the manifolds looks similar to the one on the 79. These castings and their availability is my only concern with the 351.
In fact, the whole front of the engine/accy's on the 93 look just like the 79.
I'm in salt and i've seen these castings become corroded and fail in lake eerie where i grew up at. With the 350 anything and everything is available in just about any material and finish you'd care to have.
So are my concerns about these castings for the 351 founded or not ?
What does a rebuild cost ? Say gaskets seals, valve job, hone & rings on a rh 351 ?
https://www.facebook.com/marketplace/item/1110484729908590/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Ac5f3ae57-d970-496c-8123-f7ca480c26bc
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2023 at 1:01am
I believe Supra started using the same fiberglass mix that Correct craft was using in the 90’s.  Supra is a very well built boat.  They are heavy and have less top speed than the other options including Nautique but they drive and ride well.   Ski wake is pretty good.
I prefer Chevy engines since I am so familiar with them but the 351W is one fantastic ski boat engine.  Parts might cost 20% more than the same parts for a Chevy but most are easy to get when needed.    A GT 40 engine is actually hard to beat for boat use.  Hard for a Chevy guy to admit but it is true in all respects.
The early Malibu, prior to 1990 had fantastic ski wakes but the boats do not handle like a Nautique, they do not steer as well.  Going straight, great wake, fast and light boats.   Turn them and they act up.  They do not turn the same with 5 people on board.  3 people on board they handle a lot differently.   Nice boats but test drive them and add people before buying.  I had my 1987 Malibu for 20 years.  It never handled as well as the 1978 Nautique I had for 10 years before it.   The wake was much better though.
My current 1995 Nautique wake is far better than the 1978 Nautique and nearly as good as the 1987 Malibu but the 95 Nautique handles like a sports car, 1, 2, 3 or 6 people on board it drives the same, very predictable unlike the Malibu.  I really like the 95, I need to avoid driving the 1997 and up because I hear the wake is better and they drive better.  Hard to believe because the 95 is really nice. Being much older now I no longer ski at 36 mph, more like 32 is my new norm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2023 at 7:48am
I'd say they pretty well founded since they're NLA from PCM for a lot of years now and you have to scrounge for used stuff.
The front of the engine is basically just like your 79 was.
You're asking about rebuilding a RH engine, are you sure that's what's in the boat?
Most 93's had a LH engine with the PCM 40A 1.23 to 1 transmission that reversed prop rotation and there were a small number with a RH engine and a PCM 40I 1 to 1 transmission.
By the way, parts for either of those  PCM transmissions are pretty much NLA and then you're stuck buying a new PCM 80A or 80I for a pretty good chunk of change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2023 at 2:43pm
Thank you both for the insight and technical explanations, it's exactly what i'm looking for.
MrMcD, How it drives and turns is as big a part as the ski wake. The 79 turned really hard (edit in, by hard i mean good and tight) and adding power thru the turn made it better-- it did have the rudder w/ the tuning fin and left or right it felt the same.
My only concern with supra is (as i understand has kevlar in the layup) i have zero experience with kevlar but understand it is difficult to repair.
But the supra is a nice looking boat, now if kevlar is only in tue tsm6 and not another model that would be good to know about.
Keno i didn't inquire about the engine, just went with rh in asking the rebuild cost.
Didn't know it has the pcm 40 transmission but have seen the threads about them and converting to the 80.
Personal preference would be the velvet drive.
To continue ; How do these drive turn and ski ?
yes i know it's the devils boat but theres more around in my price range, even tho i also know by the time i'm done the budget will be blown no matter which hull and price i start from.
https://www.facebook.com/marketplace/107381892625031/?hoisted_items=187027737703948
Drive turn and ski on the brendella ?
https://www.facebook.com/marketplace/item/789221232893350/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3Aafc0e726-78fd-4af6-b371-d32c948ae63c
Thank you,
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: August-18-2023 at 2:56pm
This is 100 miles around orlando.
https://www.facebook.com/marketplace/orlando/search/?query=ski%20boat&ref=global_search_module_see_more&exact=false
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2023 at 12:43pm
How about transmission length between the pcm and velvet drive ?
Shaft length ? I would install a new dual taper regardless.
Do Pcm and velvet drive share the same bellhousing, dampener plate and starter ?
Obviously looking at donor boat for chevy velvet drive conversion into a good hull, hopefully with good cosmetics, no problem with glass work.
Inquired about a boat and got an immediate reply, asked for pictures of the engine and transmission,   Haven't heard back !
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2023 at 1:23pm
Click on the link and you'll find some info. There are also links in those links Wink
Same bellhousing, same starter, but different damper plates. (different spline count) so PCM could make you pay the money for their plate.
This is for a PCM 40i (1 to 1 ratio) and BW 10-17, if you're wondering about a 40A down angle 1.23 to 1 ratio),length differences engine mounting angle differences too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: August-21-2023 at 9:27pm
Thank you Keno ! I'll be reading up.
Speaking of down angle transmissions there is a ski boat with a down angle pcm, i'll try to find the link.
Mercruiser has an installation pdf that i'll attach, it shows some 5.7 ski, ski scorpion etc with the 10-17 and some with a hurth down angle but doubt ever coming across one,
The velvet drive is the way to go in my opinion, but what the heck do i know.
Thanks again.
Heres that merc installation filter
https://www.mercurymarine.com/en/us/documents/installation-drawings/
i used it to determine engine install on the other boat without test fitting, well i had to throw a block with crank, bearings, flywheel and hub in to complete alignment but the diagrams provided all the math for the 496 mag ho on an improvised driveline. That boat and how i set it up is back on the race course, it now has a 700 hp race motor in it and was converted to sit down.
That boat was laid up in the mold as a race boat with full crash bulkheads no cabin etc etc.
It's very fast and turns very good, lots of bite with no slip n side.
New owner sent me some pics, an acceleration video and i've seen it race on the livestream.
Might go to englewood this year and see it race in person.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayoutthere Quote  Post ReplyReply Direct Link To This Post Posted: October-11-2023 at 6:30pm
Well, thought i found a boat. Watched it for a week or so then yesterday with a short list of questions, logged into facebook to try and strike a deal., didn't have to ask, The price was lowered and add changed, no title parts boat, very wary of the no title issue. Anyone know the seller or is he a member? Heard getting a title is a big deal. Keep looking.
https://www.facebook.com/marketplace/item/1360311191589008/?ref=search&referral_code=null&referral_story_type=post&tracking=browse_serp%3A6d546907-9fa9-48bb-bbd7-0bf25a93ab6c
