Drain plug |
DenDen
Senior Member Joined: July-20-2023 Location: USA Status: Offline Points: 183 |
Posted: August-30-2023 at 11:54am |
I had a 77 S. wind 20. The drain plug was located under the motor cover by the bilge pump where you could access it from inside. It also did a very good job of draining the bilge. Now I have a 75 south wind 18 and the drain plug is in the back on the outside. And it doesn’t drain the bills very good at all. Has anybody ever installed one under the motor cover in the middle of the boat. Can you even get the parts?
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10721 |
You buy whichever one of these things in the link below that you like, pick your spot, drill a hole and use some of your favorite sealer/adhesive when installing.
DenDen
Thanks KENO it’s good people like you that make forums work
