88 Nautique PCM 351W Cam specs |
Nauti
Newbie Joined: March-28-2024 Location: WNC Status: Offline Points: 4 |
Posted: March-28-2024 at 12:53pm |
1988 Nautique PCM 351W Cam specs? I found two different specs on this site for the cam lobes: 112 Degrees and 115 degrees. Can anyone confirm? Thanks ahead of time!
What we have here, is a lack of experience working on inboards.
Grand Poobah Joined: June-06-2004 Location: United States Status: Offline Points: 10652 |
There must be some reason that the only numbers you're wondering about are Lobe Separation Angles.
You can also find multiple numbers for intake lift, exhaust lift, intake duration, exhaust duration for 351w marine cams. Are you looking for a RR cam for your engine or maybe you're just curious?
