  New Posts New Posts RSS Feed - Depth Finder Addition
mossycreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mossycreek Quote  Post ReplyReply Direct Link To This Post Topic: Depth Finder Addition
    Posted: June-02-2024 at 9:42am
I have a 1993 sport nautique. I bought the hawkeye 2B to mount as a depth finder. One lake in particular in my area really requires it because of the terrain. I searched the forums and some people said to glue it in right behind the ski tow pole. I tired that and it didn't work. I may not have used enough glue in the bottom of the boat to give it good contact. I can try that again, but I wondered if anyone else had a thought or a picture you could share with me.
Jeff
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2024 at 10:01am
I installed a Hawkeye in my 1994 Ski Nautique with good results.  The spot I chose was in the starboard side of the bilge, near the side vertical wall.  I needed to find water flow that was as smooth as possible for optimum function.  The location I chose was not too far from the log, at the approximate spot opposite of the raw water intake.
DenDen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DenDen Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2024 at 10:21am
I did the exact same thing on my 75. Southwind was good results.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mossycreek Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2024 at 3:27pm
What is the log?
Jeff
andrewmarani View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote andrewmarani Quote  Post ReplyReply Direct Link To This Post Posted: June-02-2024 at 8:59pm
It's called the shaft log.  Where the shaft comes through the hull.
Builder
Post Options Post Options   Thanks (0) Thanks(0)   Quote mossycreek Quote  Post ReplyReply Direct Link To This Post Posted: June-03-2024 at 8:38am
Thank you guys so much. I'm going to try it later this week.
Jeff
