  New Posts New Posts RSS Feed - Vibration problem
Vibration problem
Jeffs View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffs Quote  Post ReplyReply Direct Link To This Post Topic: Vibration problem
    Posted: June-26-2024 at 12:44pm
I just purchased a '94 Ski Nautique with 351 engine. Nice boat but there's a vibration at 3000+ rpm. There's a ding in the edge of one of the the prop blades. I was wondering if that could be the problem or could it be a prop shaft/bushings issue?
Jeffs
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2024 at 2:22pm
Even a small ding in a prop can cause a vibration.  If the prop was hit hard, the shaft could be bent…they usually bent just aft on the strut.  A slightly bent shaft can also produce a vibration.
What is the current dinged prop?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2024 at 6:18pm
Does the vibration exist when your rev your engine to 3500 RPM in neutral?   You want to rule out an engine problem before chasing a prop or shaft issue.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffs Quote  Post ReplyReply Direct Link To This Post Posted: June-26-2024 at 11:23pm
I haven't tried that. Good point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jeffs Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2024 at 9:43am
Tried the RPM test in neutral but would only get up to 1500rpm. Must have a governor in neutral. Checked the shaft for play and it seemed pretty snug. Hopefully it's the nickle size ding in one of the prop blades.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jonny Quest Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2024 at 1:42pm
Try revving in neutral with the throttle lever moving "in reverse" instead of forward.  Be careful, as the engine will spool up quickly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KENO Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2024 at 4:09pm
There's a good chance it's the ding, so take the prop off for a trip to the prop place of your choice, since a repair would be a good thing no matter what and while it's off you can use a dial indicator on the taper where the prop sits to see if the shaft is bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MrMcD Quote  Post ReplyReply Direct Link To This Post Posted: July-05-2024 at 11:09pm
And if it vibrates after prop repair as Ken said, teh shaft is bent also.   Mine was.  It happens.
