  New Posts New Posts RSS Feed - Loose Steering Wheel
1998Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Loose Steering Wheel
    Posted: December-10-2006 at 5:12pm
The steering wheel on my 1998 Nautique, the shaft is sloppy it moves up and down a bit. Anything I can do to correct this.
Guests View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Guests Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2006 at 5:49pm
tighten it
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-10-2006 at 7:56pm
The actual shaft the wheel slides on to is sloppy. Is there a way to tighten it. Is it the shaft with splines.
MaddMarxx View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MaddMarxx Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2006 at 2:49am
sounds like the helm is getting worn!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8122pbrainard Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2006 at 6:51am
1998nautique, You are going to have to take it apart and inspect it for worn bearings/ bushings. If the wear is on a shaft and a replacement is not available then Loctite makes some great stuff for worn shafts. Pete
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-11-2006 at 7:28pm
Can I use chims or anything?
9360SAN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 9360SAN Quote  Post ReplyReply Direct Link To This Post Posted: December-13-2006 at 5:58am
change this part is ultimate.
http://www.skidim.com/prodinfo.asp?number=TELSH-91510P
it loose because a plastic bushing of the steering shaft wore.disasemble the steering base,you will find this wore part,if you find a substite to replace it,you will make it better.
Go on wakeboard
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Posted: December-13-2006 at 9:29pm
How much is this part?
Randy_in_Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Randy_in_Ohio Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2006 at 1:17pm
cost= $134.98
