OEM engine? |
Rob86
Newbie Joined: June-23-2004 Location: United States Status: Offline Points: 3 |
Posted: June-23-2004 at 8:33pm |
Hello, I've got an 86 CC and it has a Commander Mrine 351W in it. I don't know much about the history of this boat we are the second owners. I'm wondering if this is the original engine or maybe a repower? All of the other 2001's I've seen have PCM engines for power.
Tranner
Newbie Joined: May-27-2004 Location: United States Status: Offline Points: 10 |
I "had" a Commander Engine in my 85 2001.
If you look at the motor mounts, does it have "Commander" engraved or embedded on them? |
Rob86
I'll have to check the mounts. Did your 85 have a Mallory electronic distributor?
nms1991
Guest |
commander engines was optional, thwe mallory electronic distributor was not factory it should be a prestolite distributor. It was probably switched due to failure of some type in the distributor.
Tranner
Very true. My Commander motor does have the factory Prestolite distributor.
77stang
Senior Member Joined: May-19-2004 Location: United States Status: Offline Points: 342 |
you can call the factory and give them your hull id and they can tell you. they can tell you about anything you want
