  New Posts New Posts RSS Feed - Changing Tilt Helm
Changing Tilt Helm
1998Nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1998Nautique Quote  Post ReplyReply Direct Link To This Post Topic: Changing Tilt Helm
    Posted: February-03-2007 at 1:06pm
Is it hard to change this on a 1998 Nautique?
boat dr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote boat dr Quote  Post ReplyReply Direct Link To This Post Posted: February-03-2007 at 1:16pm
Aaron, this depends on the system that you are using now. If it is rotary it's as simple as remove and replaceing the existing helm a$$y.This is not hard,but if your's has the rack and pinion you will have to replace the cable also,which ain't a bad idea . If you do it now it will give you years of service w/no problems.......... boat dr
