OJ prop knocker |
pg921
Newbie Joined: March-15-2007 Location: United States Status: Offline Points: 6 |
Posted: March-27-2007 at 2:43pm |
has anybody tried this thing? ( i got it form skidim yesterday. it didn't come w/ any instructions. from what i found online your supposed to just whack it w/ a hammer and the vibrations loosen the prop so you can pull it off by hand. i think it's going back tomorrow.
tullfooter
Grand Poobah Joined: March-02-2007 Location: White Lake, MI Status: Offline Points: 2225 |
The instructions say, if it doesn't work the first time, get a bigger hammer.
Play hard, life's not a trial run.
'85 BFN '90 BFN White Lake, Michigan |
87BFN owner
Grand Poobah Joined: August-25-2006 Location: Saline, MI Status: Offline Points: 2194 |
Hammers and prop shafts are not friends.
Riley
Grand Poobah Joined: January-19-2004 Location: Portland, ME Status: Offline Points: 7957 |
Is it called a harmonic puller?
pg921
its the same thing w/ a new name.
79nautique
should be called a shaft bender instead of a prop knocker. POs send it back and get the puller
redneck7
Senior Member Joined: September-27-2006 Location: United States Status: Offline Points: 118 |
My prop shop uses a puller in conjunction w/a brass hammer...I think they know what they're doing, at least I hope so since I pay em to do it
87BFN owner
Never used a hammer to pull a prop off before. Most the time I have had them come off very easy once the nut is removed, if not I get the puller out and it slides right of. I have heard of heat being required, but never a hammer.
