  New Posts New Posts RSS Feed - 351 rebuild mix and match heads?
huey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote huey Quote  Post ReplyReply Direct Link To This Post Topic: 351 rebuild mix and match heads?
    Posted: March-28-2007 at 9:25am
Alright, I just had my 351 from my '91 SN rebuilt over the winter. One of the heads was cracked and the guy at the engine shop had one "laying around" that he did a valve job on. He told me that the casting numbers were not the same. But, it was a head for a 351 so it should work fine. From what I can gather, it looks like the head he sold me does not have hardened valve seats. I was reading some other posts on here that said if you don't have any ribs or bars on the end of the head, it does not have the hardened seats and i'll need to run a lead additive.
1. is this correct?
2. will that cause problems with my other original head that does have hardened seats?
3. is there some way the engine guy might have installed hardened seats when he did the valve job? (i'm kind of a rookie and not an engine builder. i didn't want to ask him that and look stupid)
81nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 81nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2007 at 11:22am
If they have the smaller spark plugs they should have hardened seats. If they have larger plugs you're all screwed up because they're just different heads altogether. Don't feel dumb about asking him to verify that they are the same. They need to be identical,ie; valve size, port sizing, valve springs, etc. If he knows what he's doing you'll be ok because no one would put mismatched heads on an engine. You can't have one side of the engine breathing differently than the other.
Can you post the casting numbers of each head here, Someone will know how to determine what you've got.
JoeinNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2007 at 11:26am
Sounds a bit sketchy to me, its possible they are extremely similar heads, however it is also possible there are differences in combustion chamber, runner size, valve size, etc that to me would be completely unacceptable. Give us the casting numbers and we can do some look up.
As for bars on the end equaling hardened valve seats, thats not exactly right. The GT40s have 3 bars, and the gt40ps have 4 and both have hardened seats but my heads from 78 (which have very low hours and you can have for the cost of shipping btw) have hardened seats and no bars. However if I matched one of them up with a Gt40p or a GT40 I would expect bad things to happen, I mean it might work but its nothing I would pay to have put into my 91 SN.
On the third question, yes it is possible and with better machine shops standard proceedure to install hardened valve seats when a valve job is done on older heads.
1983 Ski Nautique 2001
1967 Mustang 302 "Decoy"
Holeshot Video
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeinNY Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2007 at 11:27am
Curses Alan beat me to it..
Holeshot Video
huey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote huey Quote  Post ReplyReply Direct Link To This Post Posted: March-28-2007 at 1:23pm
Thanks guys. I'll have to track down those casting #'s. The guy did tell me they were different. But, assured me they were the same size and all that jazz. So, I hope he knows what he's doing.
On a side note. I also just ordered a new damper plate from skidim. It is the wrong size. I called Vince and he said they switched to a different style. It's totally round now instead of triangular, and the diameter is almost bigger than the flywheel itself. I was able to get it bolted on. But, it rubs on my bell housing and the edge of the starter. So, what the heck PCM.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: March-29-2007 at 9:29am
It's been a while since I did mine but I thought they where directional and had to face a curtain way (dampner plate)? Eric does it make a difference?
huey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote huey Quote  Post ReplyReply Direct Link To This Post Posted: March-30-2007 at 12:13am
So, I talked to Vince from SkiDIM on the phone for about an hour yesterday. Yes, it is directional. They make it pretty idiot proof by stamping one side with "towards flywheel". Moral of the story. Pray you don't break your flywheel damper on a '91 SN with a 351. The part I got is the "new" style, one-size-fits-all damper that PCM is now selling for all motors. This new damper ends up being the same diameter as the flywheel. With the extra width at the edges of the flywheel, my starter won't fit and my bellhousing rubs up against the damper too.
I was going to install this new one as preventative maint. to avoid the hassle later. Now I'm just hoping my old one hangs in there until end of life for the boat.
