Poor performance from GT-40? |
wasabiskier
Newbie Joined: March-29-2004 Location: United States Status: Offline Points: 8 |
Posted: April-28-2007 at 11:35pm |
Hey guys, I finally got the first pull behind our new boat ('01 AN) and was less than impressed with the hole shot. Our 91 SN with a carb engine seemed to get me out of the water faster. The new '01 AN with a GT-40 really drags out of the hole. I am not sure if this is a tuning or prop choice problem or just the effects of a much bigger and I assume much heavier boat (added tower, tanks, bow seat, trunk).
Any thoughts? I expected the same or better hole shot with the new boat based on this thought: 50HP is enough extra power to make up the difference in size/weight. '91 SN has 260HP at sea level. '01 AN has 310HP at sea level. The engine seemed to be fine otherwise. Boat topped out at 41mph which is what I expected. BTW, we always hammer the throttle so we can eliminate driver styl, etc. Any ideas on what's wrong with my GT-40? If the engine is running normal (and the weak hole shot is due to the boat size), what are my options to improve the hole shot and get more power out of this puppy? Thanks, Lorin |
Randy_in_Ohio
Do you realize that you have posted this topic three times? I would suggest going back and deleting the extas
I realize your new... welcome! Sorry I have no input on your problem |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Are you slalom skiing or boarding (which one)? The reason I'm asking is because I think I've noticed a difference in the holeshot between my older Ski Centurion (1988 w/351w) vs. several of the newer and heavier (and more HP) boats designed mainly for boarding. My older boat seemed to get me out of the water quicker than some of the newer and heavier ones when on a single ski. Here's something to think about also - Is your 01 a Pro Boss engine? If so, what grade gas are you putting in her. If it's not premium fuel and your engine is equipped with a knock senser, it could be pulling the ignition timing back and reducing power. Just a thought.
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
He's got the GT40 MPEFI motor. I doubt that a lower octane gas would cause such a noticeable decrease in performance, but its something to consider. Wasabi, I assume by Air Nautique youre referring to the direct drive model based on the Sport- not the V-drive Super Air based on the Super Sport. If so, I wouldnt expect there to be a significant decrease in performance, as the extra hp should make up for the extra weight. If you could fill us in on some RPM numbers that would be helpful. WOT numbers and the RPM you get instantly when coming out of the hole. Also let us know what prop youre running- brand, size, etc. |
Lorin, Last summer our ski club in northern Wisconsin used the AN as a tow boat. All previous summers they used SN's. It was a very embarassing summer since the AN had a very hard time getting a 12 person pyramid off the dock. I think they only managed it 2 or 3 times. Even with 3 different props it didn't improve the boat. It seemed like the Air, with its hull made for the wake for wakeboarding, was just held down with the suction of the water. The 12 people could almost pull the boat backwards even with 330HP. It even had problems with other acts because the hole shot sucks! This summer they are going back to a SN.
bkhallpass
Pete, the AN does not have a hull made for wakeboarding. It is the TSC hull. The boat is about 1.5ft longer, and about 320 lbs heavier. Also, the 330 horse is the Chevy engine. Even at 330 HP, the Chevy is known to have a weaker hole shot than the 310HP Ford GT40.
Lorin, my buddy has an 02 AN with the GT 40. Should be the same boat as yours. With the stock prop, at sea level, we get 43-44 mph at 4600 RPMs. BKH |
Livin' the Dream
Nautique2001
Grand Poobah Joined: June-14-2004 Location: Massachusetts Status: Offline Points: 2832 |
Are the tanks full when you're punching it? Hours on the engine? Those are two thoughts of mine.
Ken |
wasabiskier
I'll try to answer all questions:
Sorry for the triple post.. Webpage hung several times and I had to restart. Pretty sure I deleted the other posts. Don't know what prop is on there now. I will know tonight after I swing by the boat on my way home. Yes, Boat is a Air Nautique, which in 2001 is identical to the Sport Nautique (TSC1 hull stretched 1.5 feet). Supposed to be a crossover boat and the wake at 32mph was great (better than my '91 SN). It does have a tower and ballast but we were running with the ballast empty. GT-40 engine has about 400hrs. We are mainly slalom skiers and just starting to do some light wakeboarding/wakesurfing. I am concerned about the hole shot for slalom skiing since if it struggles to get me up (140lb guy), it will be struggling even worse with the bigger guys. I also thought about the knock sensor but did not think that was it. I am running 89 octane which at altitude should be plenty. I will get the current prop info tonight and the RPM numbers next weekend. ACME suggested a 12.5 x 15 three blade or 12.5 x 15.5 four blade given the power loss at altitude. They said it would run 300 more RPMs and 1-2 MPH faster top end. What's the downside of more RPMs?? Is it just burning more gas at ski speed? Thanks all, Lorin |
Brian, I didn't get right back to you because I needed to consult with my son regarding the details of the ski clubs tow boat last summer. I of coarse got the "raised eyebrow " and the responce of "dad how come you know everything about the old CC's and nothing about the new ones"! Well my responce was that I haven't skied in lots of years ether so I haven't kept current!
The boat they used last summer was a 206 with a tower and AN graphics on it and the 330HP. The fact is that they had nothing but problems with getting people out of the water. Previous years my son remembers they had the 310HP so as you said the hole shot was better. I also seem to remember the previous years boats were smaller and of coarse lighter. I guess I'm just going to have to spend some time over on the PN site and get educated! I will no longer assume that a boat with a tower on it and "Air Nautique" graphics is a wake board hull. |
bkhallpass
It's all good my friend. A little surprised that the 206 didn't get it done for you, but the "live testing" you did, doesn't lie. BKH
Livin' the Dream
backfoot100
I can only comment on my experiences. I have a very good friend back in WI that bought a brand new AN. I just can't remember for sure if it was a '00 or a '01 with the GT-40 engine. He only had about 30 hours on the thing and it would just do about 40.5 MPH with two people in the boat pulling a barefooter. I also did some slalom behind it and I didn't feel any less holeshot than I was expecting but we never hammer the throttle for anybody to get them out of the water. In contrast, another friend with a '97 SN and the GT-40 did have considerably better holeshot and more top end. We even lined up these two boats side-by-side and the '97 flat out ran circles around the AN.
64 Skier
I'd compare the Torque versus HP since it's Torque that yanks you out of the water. Just guessing that the torque values between the two engines is not that dissimilar in the lower rpm ranges. Probably not much different at the upper end either...but I'm sure someone on the forum will have these torque curves in their shirtpocket.
If the torque values are similar from idle to 2500 rpm's I'd say the heavier V-Drive boat with accessories will definitely be the weaker of the two boats when pulling a slalom skier. Our 2005 SN with the Excalibur grunts and groans on the big boy's....especially if their form is off. Very noticeable when the slalom skier is over 200lbs and has both feet in a narrow ski like the "Truth" or "Monza" and has layed off for several months. But if their form is correct, we can hardly tell the difference between them and the lighter skiers. Like you, I expected the new boat to run circles around the old boat (289 with slight mods). They're both SN's and run almost identical to 40 MPH, but the new boat does pull harder on deepwater starts. |
LaurelLakeSkier
Senior Member Joined: February-12-2007 Location: Wisconsin Status: Offline Points: 485 |
I saw the same thing happen at a ski show near me! :-) .....good news, the no-wake buoys did not pass. Good seeing you here Pete. |
Mark, It's great that you have joined in to this site with a great group of people. I've really enjoyed it and it is one thing I'll miss when I go up north on vacation. I'll have to go in to the library daily to use the computor to get on line and visit!
Great to here about the slow no wake but I think the fishing group are still planing on "studying" the problem. |
LaurelLakeSkier
Yep....lots of good info here. I got directed here by TRBenj after asking him about some 351 modifications on another site. I was in the process of getting parts for an engine upgrade but just before I ordered the heads Patty found some other uses for the checking account and saved me all the trouble of the engine work.
Mark, You and Patty need separate checking accounts like Didi and I do!! Of coarse that doesn't make much difference since mine is always empty anyway! Put it on your home equity!
So, you are trying to get the MC to go faster! What you need is a Nautique to foot behind! Didi, Colin and I are going to the Green Lake reunion this summer. Tim will be there. You should plan on at least stopping for a day. |
LaurelLakeSkier
Yes,,,,,the never ending problem of needing "just a few more miles per hour".
Mark, I talked to Chuck this morning and he thought you got the better top end with the new CNC machined prop. We both think you foot to fast!!!
LaurelLakeSkier
Yes....the prop helped and runs a lot smoother. After switching over to it, rpms dropped from 4900 to 4600 as well. The "need" for some extra hp to turn the prop follows....
wasabiskier
I took a look at the prop this weekend. It is a 4-blade OJ Legend 13 x 16. Would a 12.5 x 15.5 really make that much of a difference? Does the CNC machined prop really make that much of a difference? I won't be able to get on the water (and check RPM values) for the next couple of weeks. I will post numbers then. Thanks. Lorin |
Lorin, There are several threads with performance results on the switch to CNC machined props. Do a search and read up but in general both the hole shots and top ends improved. One thing for sure, everyone was impressed with the smoothness or reduction of vibration.
Mark, Did your hole shot improve too? The prop is probably the least expensive performance item you can add without having to negotiate with Patty!! |
If youre asking if going from an OJ Legend to an Acme 422 would be a noticeable improvement, the answer is yes. However, the 470 (12.5x15 3-blade) would be an even bigger improvement. I run closer to sea level with a lighter, unweighted boat, and the 470 outperforms the 422. I would expect to see 200 RPM more from the 470, and 1-2 MPH coming from the OJ. I made the same switch a year ago. |
wasabiskier
Tim,
As always, thanks for quickly and directly answering my question with first hand knowledge. You can obviously ignore my identical post on PN. I think the prop change is a good idea, just have to come up with the funds and convince the wife. I assume trying to trade that prop for an ACME will be difficult? I saw this PN post from you last summer: "You can get the 470 for $308.75 (free shipping) with our PlanetNautique discount. They were great to deal with and extended my trial period until I could use my boat last spring." Was that directly from ACME or some distributor? Bill quoted me $419 last week but I don't think I mentioned PN. Lorin |
The best price Ive found on Acmes is through Delta Propellor. Both CCFan and PN have a discount code good for 5% off there, and they ship for free. I think their prices went up slightly, but its still the best you'll find.
Acme wont sell direct for anything less than retail price. This is how they protect their dealers. |
wasabiskier
Thanks for the info. I am working on a possible trade. Otherwise, I will go through Delta. |
quinner
Some interesting comments on the GT-40 vs the Excalibur, we have had both motors in direct drives and felt they preformed very similar, although the GT-40 was in a bit larger boat, 99' Air @ 21' vs 05' 206 Air @ 20.5' both with stock props. The top end on the 206 is much better and neither boat ever had/has any issue with a hole shot, I am 225 and only need 3/4 throttle to get up quickly on a high end slalom w/1 or 2 feet in. Last summer with the 206 we pulled 4 barefooters at the same time and also pulled 3 footers deep water no problem.
Regarding the "Air" logo, it does not necessarily indicate "Wake Board Boat", on the 206 I could have ordered "Air" or "Ski" insignia's, in reality the 206 is a Ski Nautique Open Bow (SNOB). It's hard for me to say which motor pulls better because we had them in different boats however the 206 provides the best pull of any Nautique I have owned. If I was buying a Nautique for show skiing it would be a 196 with the ZR6. |
LaurelLakeSkier
I'm not sure what you paid through Delta but I got my Acme from boarditup.com. I checked and their price now is $329. They were great to deal with and very helpful.
