Whats the proper rpm? |
Author | ||
dborrelli
Groupie Joined: April-16-2007 Location: Austin TX Status: Offline Points: 67 |
Posted: May-20-2007 at 9:50pm |
I have a feeling that my rpm is way too high. At 35 mph the rpm is around 4500 full throttle (about 45 mph) and its around 6000 is this right? oh I have a 351 commander.
thanks db |
GottaSki
Grand Poobah Joined: April-21-2005 Location: NE CT Status: Offline Points: 3357 |
Likely somebody turned your tach to '6'.
River Rat to Mole |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
Need a little history: prop change? new tack? any other changes?
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
dborrelli
Everything seems to be original. I recently bought this boat and don't have the history. There is a small nick in the prop.
dborrelli
what does that mean? |
79nautique
some tach's are switable from 4,6or 8 cyl. Most factory CC tach's don't have this option, so the you need to confirm that the tach is reading right with a timing lite that has an adjustable advance and if the tach is reading right then you need to replace the prop because the pitch and or diameter is too small. Did the previous owner wake board with alot of weight in the boat? |
dborrelli
Theres really no telling what the PO did with this boat except not take proper care of it. I seriously doubt they did a lot of wakeboarding. I really have a feeling that its the prop. If so, my next question is naturally what replacement prop do you recommend me buy? And how much $$$ am I looking at?
thanks db |
79nautique
what year and model boat is it and what motor is in it? For the tach just look under the sdash and on the back you will see a switch if it is a switchable tach.
It may be ether a actual switch or a different connection terminal for 4,6,8. |
dborrelli
I have a 78 ski nautique with a 351 commander.
Bare with me on this. The back of the tach seems to have holes in it for a wire to connect(they say, 6, 6c 8c etc but im not sure because I cant get a good look at it) There is a wire coming out of the center that is connected to one of the holes but I don't know what that hole is labeled. Does any of this sound familiar or am I way off on this? |
79nautique
sounds like it might be in the wrong hole maybe so your in the ball park at least.
db, The switchable wire should be plugged into the 8c hole. There's a quick connect in the hole and on the end of that wire.
Did you look to see what prop is on the boat yet? |
dborrelli
Ill take a picture and post it later today thanks for everyones help. |
db, A picture won't tell us much. Get the dia. and pitch that's stamped in the side.
dborrelli
I cant find any info on the prop. Where would it be located?
JoeinNY
often it is stamped into the flat face on the front of the prop and covered by the washer and nut if you cant see it thats probably where it is.
Joe. |
