Airguide Speedos |
JAG459
Groupie Joined: August-12-2005 Location: United States Status: Offline Points: 61 |
Posted: June-23-2007 at 2:04pm |
Looking for two new or fairly new Airguide Speedos with white faces and in excellent condition. The speedometers in my 90 Sport Nautique have severely faded faces & needles, and one speedometer's accuracy is off and is beyond being adjusted. All the other gauges have suffered the same fate and will be replaced with either Faria or Livorsi gauges.
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21189 |
Im afraid Im not much help, as my gauges are pretty faded as well. Id be interested in purchasing your old hourmeter though- mine is broken (the face and bezel cracked off from the body of the gauge). Shoot me an email if thats doable: TRBenj@gmail.com
skicat
Platinum Member Joined: May-18-2006 Location: Duluth, GA Status: Offline Points: 1129 |
I have some new white face airguides that I think are like the 86-87 era. not sure if they work for your boat, but I can take some pics tonight If you would like.
JAG459
Definately,
Thanks, Joe |
skicat
Joe,
Here are a couple pics of the speedo. I have several of these. It measures 3 7/6" at the back (hole size) & 3 7/8" at the face. See if it works for you. |
JAG459
Looks good!! Exactly what I'm looking for. When I get home from work tomorrow I'll pull the cover off the boat and double check. I have a black alum bezel that snaps over the the speedo, and I'll need to take it off and see if the speedo face measures and looks the same as yours. If it does I should be able to snap the bezel on it. Is the 3 7/8" measurement taken from the outside edge of the bezel?
What are you asking for them. If you want you can contact me directly at jag459@earthlink.net Thanks, Joe |
JAG459
I took a look at my speedos and there are some differences ie Correct Craft Logo and the larger aluminum bezel which I think were added in 90. I would like to keep the speedometers original for that year; however, if the bezels on your speedos come off so the newer style can be installed I would be interested.
If they do come off the inside diameter of the bezel needs to be 3 3/4". |
skicat
I will have to take a look at them this weekend & see what comes off & what the dimensions are. I will let you know what I find out.
skicat
Ok, I looked at these & really don't see how they come apart. The screws ony remove the insides from the case. The bezel does turn a little but doesn't seem like it unscrews. Does anybody know if they just pry off. I didn't want to force anything unless I could find out more. They do come apart, just not sure how.
JAG459
Hi Greg,
The bezel should just snap off allowing removal or installation of the clear plastic lens cover. If your speedos have a glass lens I would say that the bezel probably does not snap off. Let me know. And thanks for your efforts. Joe |
skicat
Joe,
The lens is plastic. It looked like it snapped on, but wasn't exactly sure. I will take another look at it this afternoon when I get home. |
skicat
No luck getting the lens off. I can turn it a little, but I had no luck popping the lens off. I tried to pry with a screw driver, but didn't want to damage the speedo.
JAG459
I agree, you don't want to damage it. Thanks very much for trying anyway. I'm going to check on having new faces printed. There are always people looking for gauges so you should have no problem selling them.
kylem428
Senior Member Joined: May-31-2005 Location: United States Status: Offline Points: 263 |
how much for the gauges? I need 2 new speedos for my '83 sn 2001 that had the frog eye speedos but I know I wont be getting those from anyone. I'd like to update the whole dash a bit as I need a new tach as well. If I don't go with these gauges, any recommendations for what I should get? Is the wiring fairly uniform between manufacturers? How about the sending units?
kyle |
JAG459
Kyle
Contact Greg (skicat) for the speedometers. They should be perfect for your boat. As far as the other gauges go, the sending units for oil, fuel and temp should all be standard and work with new gauges. Look on line for VDO, Faria, Livorsi, ISSPRO, and Autometer to name a few. Its' a matter of taste and cost. |
kylem428
thanks much. how about the tach? that is mostly what I am looking for...It would be nice to just be able to swap out the units and be done...
Kyle |
JAG459
The tach needs to work with a standard ignition system and 8 cylinders. Check with the manufacturer if buying a new gauge or if buying a used gauge from a boat with an electronic ignition. Most tachs will work with both systems.
