  New Posts New Posts RSS Feed - Neutral Switch
Neutral Switch
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Topic: Neutral Switch
    Posted: August-27-2004 at 2:57pm
How did you do this? You wired through you neutral safety switch? If so, I would change it due the amperage the blower pulls and the switch may not handle it for an extended lenght of time. Also, you cannot switch off the blower if your battery is weak and you need all the available power to start the engine. I suggest you wire it in parrallel with the main blower so that both blowers come on at the same time.
64 Skier View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 64 Skier Quote  Post ReplyReply Direct Link To This Post Posted: August-27-2004 at 8:48am
In the '72 I put a second blower in the boat and wired it into the ignition switch....whenever the boat is in neutral and or while starting the blower comes on...put her in gear and it goes off. Although I did this by mistake, it kinda serves the purpose of a second blower
Good or Bad what do you guy's think?
64 Skier
66" HO VTX and 67" HO Triumph
71CC
