  New Posts New Posts RSS Feed - Speedo’s not equal
Speedo’s not equal
ddelmage View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote ddelmage Quote  Post ReplyReply Direct Link To This Post Topic: Speedo’s not equal
    Posted: October-01-2004 at 7:34pm
I have an '83 Nautique with Airguide 50 Speedos. The two speedos read exactly 2 mph different at speeds above 15mph, a little worse below. When at idle, the resting points for the speedo needles are at different locations, the faster reading speedo rests at 1/2 way between the 5mph mark and the bottom vent tube, the slower one rests right against the bottom vent tube. Is there an adjustment that can be made at the speedo to correct the difference.??
IrishFooter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IrishFooter Quote  Post ReplyReply Direct Link To This Post Posted: October-03-2004 at 11:47am
There should be an adjustment port at the bottom face of the speedo. It may require a very small allen wrench or it may have a knob in place. But theu should be equal
1979 Ski Nautique
tdkosta View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote tdkosta Quote  Post ReplyReply Direct Link To This Post Posted: March-01-2005 at 3:22pm
If you hook the pickup end hose to an air source you can acurately calibrate the speedos. Adjust the speedos individually to 36mph at 17 psi.
