GT40 head question |
Post Reply | Page 12> |
Author | |||
alph
Newbie Joined: April-15-2007 Location: United States Status: Offline Points: 14 |
Posted: November-21-2007 at 1:11pm |
I've got an 86 Martinique that I've been trying to modernize a bit. I've got about 2000 lbs of integrated ballast in it now, but I had it out the other day for the first time riding behind it and it felt under powered to me.
I've got the acme 542 prop on it, so that's not it. I think my motor is tired. Is the GT40 swap just a simple bolt on for the 351? Do I have to have PCM GT40 heads or can I get heads off of a 5.0 and slap them on? Or better yet, can I put the aluminum heads from my old 65 stang on the 351 block? For some reason I remember somebody telling me that wouldn't work because of deck height. Any feedback would help greatly. Thanks. |
Grand Poobah Joined: June-29-2005 Location: NWCT Status: Offline Points: 21183 |
If you havent already, give the boat a tune up before you start replacing parts. Proper timing, a well-tuned carb, and new cap/rotor/plugs/wires will improve performance and reliability.
Yes. GT40p's are better and cheaper though.
Automotive heads are fine. Bolt holes will have to be drilled out to 1/2" when installing 302 heads on a 351w.
Big debate as to whether or not aluminum heads are a good idea on a RWC motor. Do your research and decide for yourself. Any 289/302/351w heads should bolt right on. |
alph
So GT40p's are PCM heads?
alph
I had a friend recommend the edelbrock carb, so I put that on. Plugs and plug wires are all brand new. Rotor isn't. I'll check on that. Carb was freshly tuned so that's not it. I'm pretty sure timing is dead on.
The last time I did a compression check each cylinder was completely random. I'm figureing I've either got some valve issues or some ring issues. thoughts? Thanks for the input on the heads. |
What do you mean by "completely random"? If your methods were solid and the cylinders varied by more than 10%, Id do a leakdown test. That will tell you if new heads will solve your compression issues or if you should save for an engine rebuild instead. |
alph
Random ranged from 125 to 75 on one side of the engine.
How do you do a leakdown test? |
TRDon
Groupie Joined: December-22-2006 Location: United States Status: Offline Points: 65 |
cant just get them off of any mustang, has to be a 93-95 cobra or a 95-96 explorer (GT40P) Other mustangs had (for 87-93) the E7TE head which may be better for performance, but isnt worth the swap IMHO. If you have the tools and skill to port the E7s then it may be worth it. Ski dim sells the heads for an astronomical price, you can go on corral.net and get a set of used for under 500 shipped vs ski dim that have them for over 1 grand a piece
85 2001 351 240hp FS
93 sport |
nuttyskier2002
Gold Member Joined: September-28-2005 Location: United States Status: Offline Points: 669 |
A true leakdown test requires a special tool to do properly. The tool is a small manifold made of pipe fittings, gauges, an air pressure regulator and hose and is supplied compressed air. There are two pressure gauges (0-100 psi range) which are separeted by an orifice that meters the airflow supplied by the compressor (shop air). The regulator is set to 100 psi (indicated by the first gauge). Air flows through the manifold and feeds the first gauge and the orifice. On the other side of the orifice is the second gauge and a fitting that will screw into the spark plug hole of the cylinder under test. With the piston set on the compression stroke (both valves closed), the regulator set to 100 and the outlet of the tool (spark plug fitting) feeding the cylinder... you compare the readings between the first and second gauge. Readings should be within 10% of each other. The closer the second gauge reads to 100 the better. Now, if you have a leak, you can listen and detect where the air is going and narrow down what is wrong (if anything) with your engine. I know this is rather lengthy, but it is a good test because you can often isolate where the problem is. If there's something you don't understand and like further explaination....write back. Hope this helps. Brian |
Former boats: 88 Ski Centurion Tru Trac II 59 Chris Craft Capri (woody) |
alph
Brian, that does make sense. Thanks. Where can I get one of those tools?
Is that one of those rentals, or would I have to buy? |
nuttyskier2002
Here's a link to one that I found on line: http://www.powerhouseproducts.com/catalog/Images/2006pdfs/ph26.pdf Scroll to bottom of page.
Also try NAPA, Snapon or Mac Tools. I pieced one of these things together one time about 10 or 12 years ago. The critical part is the orifice size between the two gauges. I don't remember the size though. If you get it wrong your readings will be off. |
Google leak down tester, all kinds of info there including how to make one.
jbear
Gary: You didn't work and grab some of that double-time and a half?
john |
"Loud pipes save lives"
John- No,Son home from school,and since we lost Mom this summer,Dad home for 1st time in 20 yrs.Just got rid of same boss I had for 4 yrs who thought quanity was more important that quality,so I haven't worked much ot in last 3yrs.As you get older there are some things that are not as important and others you will not tolerate, but you know that.
jbear
Most every boss in my last 10 years had the same attitude. Funny...they kept coming and going and guys like me just kept on doing the job our way. Wonder what that meant.
Know exactly what you meant as to the importance of somethings. And as to the ot...always worked lots...don't have any of that money left...wish I'da spent just a ittle more time at home on the weekends and evenings. Life really changed for the better when I swore off the ot my last few years...didn't miss the money either. Have found out here latrly that you can life on lots less...you'll find out soon. Then you can come and visit. alph; sorry for the thread jack. ReidP found me a set of GT40p heads at a very reasonable price and I love 'em. He'll have to chime in as to where he got them...I forgot...but I think they were from here in Florida. john |
I think someone here steered me here
http://www.tristatecylinderhead.com/catalog/product_info.php?products_id=40&osCsid=13ee3e943670cdd4daf9d981cc52152d John,did you actually notice a difference? Reid was talking heads with me when I was trying his props.There would be a reason to work some OT! |
jbear
I think mine came from Clearwater Cylinderhead...but not really sure...Reid would remember. And yes...in combo with my new Performer manifold I bought from nuttyskier on here I noticed a big difference. Was very happy with the upgrade. There was a thread from when the guys put everything on for me complete with pictures but I don't know how I would go back to find it and link it for you.
john |
nuttyskier2002
John, that intake is actually a Power Plus Typhoon by Professional Products. The P/N is 54023 for anyone who is interested in purchasing one. They are the most reasonable priced Ford intakes (when buying new that is).
I remember reading it,but forgot they were P's
79nautique
I have a 54024 the chrome version, new in the box, for sale if anyone is interested.
TRDon
it is a knockoff edelbrock performer cast in china. The casting quality isnt nearly as good as a edelbrock. It is a great piece for the money and if you put a couple hours in with a dremel or air grinder to clean up the casting flash, it is even better value. |
93 sport |
79nautique
I would disagree with you completely. The intake we installed on Johns had no flash issues, and the Chrome version I have is flawless, both castings are equal to the Edelbrocks and the professional products design is much better in several area's. so are you talking from personal experince or quoting BS from a book/magazine because it sure doesn't sound like you have ever held a professional products intake in your hands. |
TRDon
WOW. That was pretty accusational. I play with fords a LOT and I am part of the local mustang club and i help manage their forum board. I have done a lot of work on my car any other peoples cars in the club over the past 4 years. I have seen plenty of intakes and played and installed several. I have done a lot of porting work on intakes and am dabbeling a bit in heads now too. What I write on forum boards isnt just to say what I have heard or read on frivolus websites but what I have personally experienced. There is, in what I have seen with my own 2 eyes, more casting flash and a more porus sand used in the casting process of the PP intake than the edelbrock. I never said it was a problem, I just said there is more there than the eddy. The PP is not better in any area than price because it is based off of the performer design. It is cheaper because it is made in china and that is the difference in price.
So let me ask you this in rebuttal, have you ever held an edelbrock piece in your hands or are you quoting BS form a book or magazine. Thanks for hammering me and acting like a jerk like I have no clue. Im not some hopped up 18 year old who never seen an engine before, but you are quick to assume that. I never once it was junk or said anything negative to justify a comment like that form you. |
93 sport |
Jim_In_Houston
Hmm... I'm speachless. But, as far as hammerings from 79 you ain't seen nothin' yet. That was pretty mild. Just wait until he's off his medication. So, do they have hot rods and racing in China? You never know about the world anymore. That Chinese company could be owned by Edlebrock and the minute they close their USA plant the Edlebrock name will start showing up on the Chinese castings. You never know... I wanna be a Grand Poobah too. And Edelbrock, if that's not your plant I'm totally sorry for the slanderous comment - don't sue me, it was only wild and crazy speculation from a guy setting near a bayou on a cold an rainy day with a glass of Turkey and 7-Up. I have no facts.
jbear
Wow again. J-I-H and 79 are rolling into holiday form.
Actually guys...you all know how clueless I am. Thanks Brian for clearing up just what I have. And thanks again for getting it to me at the right price. As 79 said...when it went on it looked great and performs the same way. john |
Jim_In_Houston
Hey jbear. Actually, from Thanksgiving to Christmas is the only time I drink hi balls (bourbon and soft drink over ice for all you kids out there). It's a religious thing with me.
When did auto spell checker show up on this thing???? Don't tell me it's been here all the time - I'm all ready losing my mind. I think because the '68 did not make it into the water one time this year. Not one time! It's been a crazy rainy year down here in Southeast Texas. |
jbear
Jim; Thanksgiving to Christmas is the only time I don't do Beam and Diet Coke. Something about the Holidays.
Spell check has been here for awhile. Haven't you noticed how it cleaned up 79's posts. Used to be only us guys who knew him could make out some of his posts...now everybody can understand him. Very bad that the '68 never got wet. I remember some of your posts with pics of the spring flooding...just kept it up all summer huh? john |
79nautique
spell check, where? why?
actually I installed a performer on mine, when I replaced the motor and I bought a chrome PP. liked the extra water passage, and what looks to be less porting work too. Was going to use it with the DO0E heads I had reworked. But there both sitting in a box now. |
87BFN owner
Grand Poobah Joined: August-25-2006 Location: Saline, MI Status: Offline Points: 2194 |
79nautique
notice all of the flashing on the casting by the way. Oh and you only get flash on molded/pressure cast/formed materials, like die casting or plastic injection molding. Green sand molds equall no flash
