transmission additives |
Author | ||
eric lavine
Posted: April-09-2008 at 3:56pm |
snake oils are in no way recommended in any transmission, i just blew a piston out of a cylinder and cut my guys finger wide open from the force of the piston being lodged and then letting loose, the transmission had a slimey additive in which was the cause. the stop leaks are basically a brake fluid that swells rubber to twice its normal size. a transmission with additives in it typically are more expensive to rebuild because of the damage it causes. it is a band aid, and if you need to add an additive to stop a leak...pull the trans and repair the leak correctly
wakesurfer
Senior Member Joined: April-22-2008 Location: United States Status: Offline Points: 110 |
ANyone think additives are good? |
backfoot100
Insert cricket sounds. . . . . That deafening silence should answer your question. |
Eddie |
BuffaloBFN
LMAO Eddie!!!
eric lavine
actually the guy on my other shoulder thinks thier good
160 views and no positive comments? I guess we don't have any marketing types in the lubricant additive industry that can tell us about all the benefits!
79Tique
Senior Member Joined: September-04-2006 Location: United States Status: Offline Points: 380 |
I once had a pile of *************** truck that had a rear differential that would make a terrible whine on the highway. This good old boy in town told me to put banana peels in it. It worked great! That thing quieted down and worked for another 20,000 miles.
Work to live, not live to work.
Gabe, Did you ever think that it may have run for 40,000 miles without the banana peels? |
eric lavine
oil would've done the same lol
Riley
I've heard adding sawdust can help out an old tranny that's beginning to slip.
BuffaloBFN
That's from an old Andy Griffith Show! |
Riley
You saw it, too? That was about 40 years ago. |
eric lavine
try it Riley, let us know what happens lol
79Tique
[/QUOTE]Gabe, Did you ever think that it may have run for 40,000 miles without the banana peels?[/QUOTE]
It might have any way the motor gave out and the diff was still going. It was a $750.00 Isuzu when I got it and was not a good truck when it was new. (College days) |
NOT ON THE DEARBO!!! |
79Tique
Eric, I actually tried a few different oils including some crap the guys at the auto parts store said would do the trick. Nothing made it stop humming. I new the truck was ready for the dump when I did the banana thing. I did it more to get a rise out of my friends who were with me when the guy told me about it. I was totally surprised when it worked. A good bit of beer was involved when the bananas went in. Please note the old boy was clear that it should only be the peel. |
I'm old enough to remember the days when people were trying to smoke the banana peels too!!! FYI, it didn't work!
boat dr
Pete was this a tale or did you INHALE................Boat dr
Riley
Eric, I can just imagine your post the day you pull a tranny apart and it is gummed up with sawdust.
BuffaloBFN
Yes, do tell! LMAO Doc, I suspect he's one of those long haired hippie people at heart...or maybe that's me?!!? |
You mean I was supposed to inhale??? |
