flight control tower |
nauti girl ![]() Groupie ![]() Joined: January-20-2004 Location: United States Status: Offline Points: 61 |
![]() ![]() ![]() ![]() ![]() Posted: January-22-2004 at 1:53pm |
I have a 78 Martinique that I am considering adding a flight control tower to. I noticed in the diary pictures that "Ben" fabricated a tower to his boat. I'd like to know where I can find the fittings for this project.
Nauti Girl
--I think my husband uses his own login now! |
Lakeview ![]() Senior Member ![]() Joined: January-06-2004 Location: Branchville NJ Status: Offline Points: 247 |
I would advise against adding a tower to your martinque.The towers on the newer boats have structurally reinforced mounting points to enable the tremendous forces to be distributed equally along the deck surface.Your boat was designed as a pleasure/ski boat,not a wakeboard tower boat,don't risk the serious damage or injury possibility.
Lakeview
1992 Barefoot Nautique 1967 Barracuda SS 1967 Chris Craft Cavalier |
882001 ![]() Senior Member ![]() Joined: October-21-2003 Location: United States Status: Offline Points: 332 |
i disagree the deck on any nautique,that i have run across. is easily capable of supporting a tower. im gonna put one on my 2001.
try www.diytowers.com and www.inboardtalk.com hope this helps.. |
kemah texas
1988 skinautique "2001" |
veedub88 ![]() Newbie ![]() Joined: January-23-2004 Location: United States Status: Offline Points: 3 |
I have used my 1977 martinique (see diaries) all last year with no problems whatsoever. There is only like maybe 200 pounds of force on the wakeboard rope. The fiberglass area where I mounted the tower is pretty thick. If you are going to wakeboard, you need a tower, so start building! I got the fittings online, just do a search for Kee-Klamp fittings. You have to match them with the corresponding pipe size. They are about 8$ a piece and they save tremendously on fabrication. Check out http://www.inboardtalk.com/tower/tower.html and http://www.onlinemetals.com/
Thanks for all the info. We appreciate it tremendously.
Nauti Girl
Canadianboater ![]() Newbie ![]() Joined: February-01-2004 Location: Canada Status: Offline Points: 1 |
I have a 69 Correct Craft Southwind with a tower. These old boats are more then capable of handling the pressure of wakeboarding. Have fun, play safe.
tryan ![]() Senior Member ![]() Joined: November-12-2003 Location: United States Status: Offline Points: 345 |
i inspected all the various towers last night at the boat show. correct craft was the only boat line with a substatial mounting pad. we'll see what happens in the long run.
ANYONE that makes a tower (edit...for resale) must get a licence from cc to do so. they own the patent. |
CCraftSkierFan ![]() Newbie ![]() Joined: January-23-2004 Location: United States Status: Offline Points: 10 |
Try checking out this first. Bought one last year and couldn't be more happy with it. You can still keep your original ski pylon.
Flitepipe |
1975 Correct Craft Skier 16 302 Commander 220HP, towed with a 1989 F250 4x4, 7.3L diesel supercab
