  New Posts New Posts RSS Feed - painting a nautique
painting a nautique
nautiques1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautiques1 Quote  Post ReplyReply Direct Link To This Post Topic: painting a nautique
    Posted: January-22-2004 at 11:18pm
Does anyone have any experince on what type of paint to spray on a boat that will last. I have a 69 Nautique that I would like to bring back to life. Also the wood chins on the side of the hull how difficult are they to remove for refinishing or is it worth taking them off.
Gavin Grant
Desbarats Ontario
Canada
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2004 at 12:03am
have you tried wet sanding?
reidp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote reidp Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2004 at 1:53am
I'm definitely with Tom, in trying to wet sand and compound it first to see if there's any life left in the gelcoat. It's quite a bit of hard work, but nothing beats seeing that old finish come back to life. That original gelcoat is many times thicker and a lot more forgiving to trial and error than painted finishes, such as on a car.
As for that wooden spray rail at the chine, I removed some rotted ones recently and what a pain. It was screwed/fastened from BOTH the inside and outside and obviously installed before the floor went in, so accessing the inner screws is difficult without removing adjacent flooring and foam. I ended up cutting them off from the outside as I had no plans in going beneath the floor level. I've yet to replace the wood, but I did caulk the holes and put the boat in the water for a quick ride and verified quickly why they were installed originally. Very wet.
ReidP
1973 Mustang
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautiques1 Quote  Post ReplyReply Direct Link To This Post Posted: January-23-2004 at 10:46pm
I might be able to bring the sides up but this boat was abused it was in lake huron and the waves banged it against the dock and ripped the rub rail off. So the deck needs to be resprayed after the fiberglass repair. Thanks for the info on the chine rail as it looks like its on there pretty good I think i'll go with the original plan to refinish it on the boat. Have you guys ever seen a swim platform on the older ones as this one has a beauty teak one. The other thing I am looking for is the rubber trim that the windshield sits on its a wrap around glass.I tried Taylor but they said they don't have any of the older trims. Thanks for all the good info gents.
Gavin Grant
Desbarats Ontario
Canada
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2004 at 1:39pm
if you are just going to fix the deck, spray it with gelcoat instead of paint. spraying gelcoat is just labor intensive to get chewing gum to come out to a shine. minicraft.com (donald) sells materials and a gallon will cover 80 sq ft if you can get an even thickness. you might pay someone to spray it and sand it yourself. ask board member marc diller his recommendations. i am just a novice.
rubrails.com (alan) sells stainless and aluminum rail. shipping kills on the 20' length.
try classic boat connection for the lower seal.
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2004 at 5:42pm
GAVIN the windshield seal is easy.i bought one for the barracuda just last month $23.00 here it is.TAYLOR MADE white vinyl windshield deck channel.110" long part#826500 herne marine cinn ohio 513-874-2628 they will ship it to you. i just called them.they have 3 in stock.after these 3 are gone they cant order any more. somebody should jump on the other two. as for paint.i like the IMRON.it won't fade.just DON'T spray it over lacquer primer.
kenny g
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: January-24-2004 at 11:54pm
thanks kenny. i am going to order one for the 60.
how is canada on paints and chemicals? can that stuff be shipped over the border?
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: January-25-2004 at 9:14pm
awl grip
Post Options Post Options   Thanks (0) Thanks(0)   Quote nautiques1 Quote  Post ReplyReply Direct Link To This Post Posted: January-25-2004 at 10:12pm
Ken thanks for the info on the windshild trim I will call them tomorrow. I was thinking about IMRON I live on the U.S border at the northern tip of Michigan so its just a matter of a 5 minute drive to pick anything. The black on the boat in the photo looks like a mint job hats off to the man on the gun. Two winters ago I built a 20' ceader strip sea kayak 500hrs and 5 months work not sure which project will be more difficult I think the sound of the duals will pay off.
Gavin Grant
Desbarats Ontario
Canada
