  New Posts New Posts RSS Feed - Hot water inst. in fresh water cooled eng
DESSER.dk View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DESSER.dk Quote  Post ReplyReply Direct Link To This Post Topic: Hot water inst. in fresh water cooled eng
    Posted: January-23-2004 at 7:36am
Are there anybody who have installed hot water shower in a correct craft with fresh water cooling systenm installed ??
I like to do that, but how ???
jens c
Alibuma View Drop Down
Guest
Guest
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alibuma Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2004 at 1:21am
this was just talked about on planetnautique as well. my response is to start researching heat exchangers and start fabricating. I am sure you could come up with something. Would you want your shower to spray the same water coming out of the lake? If not, you could install a watertank in the boat and fill it up before you leave home. what kind of boat, are you in salt water?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alibuma Quote  Post ReplyReply Direct Link To This Post Posted: February-07-2004 at 1:23am
www.strictlyinboards.com
www.uwstoutwaterskiteam.com
Post Options Post Options   Thanks (0) Thanks(0)   Quote DESSER.dk Quote  Post ReplyReply Direct Link To This Post Posted: February-08-2004 at 4:06pm
I have a correct craft 1996, but i am going to install a heat exchanger because of there is salt water where i live.
your idea with a water tank could be used , but then you will need another heat exchanger for this 8i am lucky ,I have a little one in spare, so maybe I should try that. In the water tank there should be a little pump to circulate the water and another one (?) for the shower. There could be some problems with the water tenperature (?) the water in the tank could reach motor temperature 85° Celsius....
jens c
tryan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tryan Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2004 at 12:38am
there is a shower on ebay by a planet nautique member.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alibuma Quote  Post ReplyReply Direct Link To This Post Posted: February-09-2004 at 11:42am
yes, you are right... if you had a freshwater holding tank, you would have to make sure the temp doesnt get too hot. I dont know what to do about that. On the other hand, you could leave the water in the tank as cold water and let it heat-on-demand when you pump it. Make the heat exchanger after the watertank. I do not know how much heat cold water could pick up passing through a heat exchanger only once.   Just a thought.
