  New Posts New Posts RSS Feed - Ring for top of ski pole
barr 68 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote barr 68 Quote  Post ReplyReply Direct Link To This Post Topic: Ring for top of ski pole
    Posted: December-16-2004 at 10:22am
I need the ring (threads into pole) for the top of the ski pole for my '68 barracuda. At some time in the past someone replaced the ring with a lifting eye.I removed the eye and want to replace it with the correct part. Does any one have one or know of a source. Also, the boat has 210 hp 318 Chrysler. I have the specs to adjust the valves but don't know if these spec are for engine at operating temperature or cold. I would like to ajust them with out un winterizeing the engine if possible. Any input /help is apprieciated. Thanks Jim/ Barr68
barr68
Jim_In_Houston View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim_In_Houston Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2004 at 1:17pm
Good luck on this one. If I needed that part I would probably have it fabricated, polished, and chromed. My guess is a sympathetic fab shop could do it for a couple of hundred dollars.
Bend the appropriate diameter cold rolled steel rod into a circle, weld the vertical bar into the center and a base, polish it with a high speed hand held polisher, and send it to a chrome plating house. You have to really want it though.
Let me know your email address if you want a close up pic of mine.
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: December-16-2004 at 3:17pm
The manual for that engine is in the reference section. Good luck with the ring. I would try old time marinas or dealers to see if they might have a used one. Try callig Blue Ridge in Lynwood Wa they had the manifolds for the old 318 they may have some old ski rings.
ccskier16 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccskier16 Quote  Post ReplyReply Direct Link To This Post Posted: December-18-2004 at 2:13pm
Try marinehardware.com They don't list anything like the ring in their catalog, but I am sure they would have the resources to make it the way it should be.
kenny g View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kenny g Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2004 at 1:38pm
barr68. i had the ring made for my 68ss at a shop in cincinnati.polished SS & looks real nice.it took forever to get it done,but worth every $ .e-mail if you need the #
kenny g
captan1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captan1 Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2004 at 7:33pm
I ran into the same problem, I found a used one at Central Valley Marine in San Jose, ca. Someone sawed off the original one to put a higher pole on.
mrese View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mrese Quote  Post ReplyReply Direct Link To This Post Posted: December-20-2004 at 11:23pm
The guys in the service dept at South East Correct Craft do a good bit of Refurbing old Correct Crafts. Give them a call for more ideas if you need.
