  New Posts New Posts RSS Feed - ’98 Steering Cable.
’98 Steering Cable.
RIPnSIX View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RIPnSIX Quote  Post ReplyReply Direct Link To This Post Topic: ’98 Steering Cable.
    Posted: June-09-2008 at 1:17pm
Hey guys, My '98 steering went terribly stiff on me the other day, so it seems that I will have to get a new cable. Is there anyone on here that can the the Correct Craft cables at a discount? Also, is there some instructions to do this myself? I don't feel like paying the dealer 300.00 bucks to do something I could do at home in a hour. Let me know.
Thanks in Advance!
If you don't fall, you're not trying hard enough.
If it doesn't hurt.. Go Bigger.
Tubing Sucks.
David F View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2008 at 3:58pm
Get the cable at White Lake or your local dealer. My dealer was only $5.00 more than White Lake and had the cable in stock (+/- $179.00). Replacement is very easy.
Pull out from the helm after tieing a rope to the tiller end. once out, tie rope to new cable and pull tiller end back through from helm. Bingo you are done.
Cable Rack simply unbolts from helm. Remove bolt from Cable rod/tiller and remove large nut from torque tube (lareg nut is part of cable). Reverse to reinstall. Very easy.
79nautique View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 79nautique Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2008 at 4:13pm
the cable is stiff enough that you really don't need the pull rope just start pushing it through the tube in the hull and it will come out in the bilge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote David F Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2008 at 4:39pm
yep, true enough. The rope just made it easier for my young son to pull, while I guided the cable through from under the dash.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RIPnSIX Quote  Post ReplyReply Direct Link To This Post Posted: June-11-2008 at 4:40pm
Hey thanks guys...I might jump into this this weekend. Are there any discounts available at White Lake?
Tubing Sucks.
p/allen View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote p/allen Quote  Post ReplyReply Direct Link To This Post Posted: June-12-2008 at 10:08pm
Silly question here . Do you replace just the inner cable , or do you also replace the outside casing with the cable in it as one unit?
Pat
My 72 Skier
Rock River
Dixon,ILL.
NCH2OSKI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCH2OSKI Quote  Post ReplyReply Direct Link To This Post Posted: June-13-2008 at 12:50am
You replace the entire unit.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RIPnSIX Quote  Post ReplyReply Direct Link To This Post Posted: June-18-2008 at 2:28pm
well that is done. pretty easy too. Thanks for all the help guys.
Tubing Sucks.
